91 teg bet you cant hep me figure this one out!!!!!
Old May 9, 2006 | 06:20 PM
thug_image2k7's Avatar
Default 91 teg bet you cant hep me figure this one out!!!!!
Hey guys
Im new to forums so bear with me..
My friend owns a 91 teg with a b16 swap in it...ok...
it ran fine and the only thing bad was the suspension...
one day he hooks up a system into his car and being the rookie he was he grounds out the battery...like ratchet to positive and negative....
he finishes his install not thinking anything is wrong and tries starting it and it wont start..
I went over to check and he had fuses blown all over..after switchin out 6 fuses still nothing...so now heres the problem...
no spark
no fuel...
maybe burnt wiring somewhere..?
already checked timing, fuses and main relay...
please help..
Old May 9, 2006 | 06:53 PM
Black Widow g2's Avatar
Default Re: 91 teg bet you cant hep me figure this one out!!!!! (thug_image2k7)
well, sounds like you popped every fuse in the damn car. replace them all and you're going to have to find out if all the wiring is still good... which is going to be a pain in the ***.
have fun, bro.
Old May 9, 2006 | 06:58 PM
Hybrid_DA's Avatar
Is the battery working alright? i had some what the same problem when i put my battery in the trunk, it ended up being that the fuse going to my battery wasnt big enough, if you got a system check to see if you have a fuse going from the battery to the system otherwise your system might be messing up your whole wiring and fuses.
Old May 10, 2006 | 04:06 PM
thanks for all the input...
thinking its the wiring im switching out engine bay wire loom...
will keep you guys posted...
Old May 10, 2006 | 04:08 PM
chile's Avatar
did that before and it turned out to be a dead battery...
Old May 10, 2006 | 04:34 PM
CleanLikeJdm's Avatar
Hype-R Stalker
You didn't kill the ecu did you?
Old May 10, 2006 | 04:42 PM
RHDintegXsi's Avatar
Default Re: 91 teg bet you cant hep me figure this one out!!!!! (FlatBlackTeg)
did you check the main fuses? they are usually the larger rating ones screwed into the engine bays fuse box
bank2me
Feb 20, 2011 04:58 PM
ubermoc
Aug 29, 2007 01:32 PM
speedrcr24
Oct 9, 2006 05:14 AM
aLLmOTORFienD
Jun 27, 2004 10:51 AM
shadowdawn
Oct 1, 2003 05:03 AM
