Can anyone tell me what these connectors are called?
Old May 9, 2006 | 05:52 PM
justint's Avatar
Default Can anyone tell me what these connectors are called?
I once used these connectors by 3m to install a head unit connecting the install harness to the reciever harness. They were plastic, you inserted the two wires into opposite ends, close the snaps which locked them in. Very easy, and they seemed to work fine. Anyone know the brand name, product name?
Old May 9, 2006 | 06:11 PM
mrdeadman's Avatar
They let me pick
Default Re: Can anyone tell me what these connectors are called? (justint)
splicers?
Old May 9, 2006 | 06:15 PM
shyboy817's Avatar
Butt connectors?
Old May 9, 2006 | 06:59 PM
justint's Avatar
Default Re: (shyboy817)
Nope not but connectors. These are hard plastic and clip onto the wires
Old May 9, 2006 | 07:28 PM
94_DC4's Avatar
Default Re: (justint)
They are T taps
Old May 9, 2006 | 08:14 PM
rcurley55's Avatar
New User
and they should be avoided at all costs....
Old May 10, 2006 | 04:26 AM
B18C_EJ8's Avatar
Actually, they're called scotchloks... And as previously stated, should be avoided.
You should be using a wiring harness adapter; unless, of course, you (or someone else) has already hacked off the plug.
Old May 10, 2006 | 01:19 PM
incubus's Avatar
Default Re: (B18C_EJ8)
scotchlocks are not a secure connection and will often lead to problems down the line, I.E. power cutting in and out.
Old May 15, 2006 | 06:38 PM
97civicB18C's Avatar
Default Re: (incubus)
those are bad you should use a harness because that adapters cause alot of shorts and you will fry your amp
Old May 19, 2006 | 04:51 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: (rcurley55)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcurley55 &raquo;</TD></TR><TR><TD CLASS="quote">and they should be avoided at all costs....</TD></TR></TABLE>I agree with ya. CUT, SPLICE and SOLDER is the best connection!!
GSR-EG-92
Audio / Security / Video
Jun 15, 2009 11:52 AM
GuCCi_GSR
Oct 27, 2008 05:09 PM
JDM-MONKEY
Jul 23, 2007 03:45 PM
pinoyboiwonder
12
Feb 24, 2006 05:45 PM
bmw626
Aug 24, 2005 11:47 AM
