Toda C's vs Skunk Pro1 + cams on a 1.8 ITR motor.
Old May 9, 2006 | 05:41 PM
b19coupe's Avatar
Default Toda C's vs Skunk Pro1 + cams on a 1.8 ITR motor.
Both cams tuned on the same dyno/same day. Toda C's have a much stronger mid range on this motor. Peak power on both is close.
Old May 9, 2006 | 06:08 PM
Combustion Contraption's Avatar
Great post todd.
Outdated Toda technology still bringin the heat, huh?
Old May 9, 2006 | 06:36 PM
Tbone's Avatar
Default Re: Toda C's vs Skunk Pro1 + cams on a 1.8 ITR motor. (b19coupe)
Todd thats about exactly how the pro-1's beat my buddy 4's when I did them in my motor.. But the skunks were the ones who beat the buddies in the mid like that and the buddy caught back up and peaked higher..
Great info man , glad your still providing such tests to help the community.
Old May 9, 2006 | 06:40 PM
dinko's Avatar
Default Re: Toda C's vs Skunk Pro1 + cams on a 1.8 ITR motor. (Tbone)
that torque is nice.
Old May 9, 2006 | 06:56 PM
UncleD's Avatar
Default Re: Toda C's vs Skunk Pro1 + cams on a 1.8 ITR motor. (dinko)
Nice info man!
Old May 9, 2006 | 07:34 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
Default Re: Toda C's vs Skunk Pro1 + cams on a 1.8 ITR motor. (clean rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">Nice info man! </TD></TR></TABLE>
yeah very nice
Old May 9, 2006 | 08:07 PM
Dat1BVtecN's Avatar
good ****, thanks for sharing the info
Old May 9, 2006 | 08:13 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: Toda C's vs Skunk Pro1 + cams on a 1.8 ITR motor. (Dat1BVtecN)
Wow todd that took me by surprise did you get a chance to beat on both cams on the pavement if so ... Difference in feeling?
Old May 9, 2006 | 08:23 PM
B18C1_POWER's Avatar
Default Re: Toda C's vs Skunk Pro1 + cams on a 1.8 ITR motor. (HOOKUPS)
nice, engines specs?
Old May 9, 2006 | 08:58 PM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOOKUPS &raquo;</TD></TR><TR><TD CLASS="quote">Wow Todd that took me by surprise did you get a chance to beat on both cams on the pavement if so ... Difference in feeling?</TD></TR></TABLE>
The Pro1's "feel" faster. Go figure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1_POWER &raquo;</TD></TR><TR><TD CLASS="quote">nice, engines specs? </TD></TR></TABLE>
ITR block and crank.81.5mm Wiseco pistons. Compression around 11.5:1. Pump gas. Import Builders ported head-stock ITR valves. Portflow valve springs and retainers. Valve job redone by Portflow at my request (more flow). Import Builders ported ITR intake manifold. RPM 70mm-tapered to 66mm throttle body. RC 440cc injectors. Velocity stack intake. Hytech 1.8 ITR header. No cat. Mugen cat back. Tuned on Hondata S300
Old May 9, 2006 | 10:03 PM
dragonz04's Avatar
nice
Old May 9, 2006 | 11:30 PM
camlob's Avatar
Default Re: Toda C's vs Skunk Pro1 + cams on a 1.8 ITR motor. (dragonz04)
I was just holding a set of TODA C2's last week! I went for Jun 3's for the stock idle characteristics. TODA C2 big lobe is at 12.5! But good nos considering your compression!
Old May 10, 2006 | 06:25 AM
slofu's Avatar
looks as though the same killer ramp angles on the Todas which have been known to eat rockers and timing belts may also render higher dynamic cyl pressures, since valves can be slammed open/shut faster.
is anyone (with a cam doctor) able to give us a ramp rate comparison?
now that i think about it, i recall seeing some old IB graphs and others which seemed to indicate that the smaller bore Bs liked less severe ramps than the larger bore setups with the same static compression ratios. this leads me to wonder whether the Pro1s have yet steeper ramps than the Cs.
Old May 10, 2006 | 07:05 AM
EK Josh's Avatar
Default Re: Toda C's vs Skunk Pro1 + cams on a 1.8 ITR motor. (slofu)
Great post.
Old May 10, 2006 | 08:05 AM
wildoutwhitegsr's Avatar
Were the cam gears tuned as well for each setup?
Old May 10, 2006 | 08:09 AM
b19coupe's Avatar
Default Re: (wildoutwhitegsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wildoutwhitegsr &raquo;</TD></TR><TR><TD CLASS="quote">Were the cam gears tuned as well for each setup? </TD></TR></TABLE>
Yes.
Toda C's-+5,+3.
Pro1+----+4,+2.
The Pro1+ cams seem to have bigger primary and secondary lobes. The car would not idle with the Toda C program, once the Pro1+ cams were installed (at 0,+1).
Old May 10, 2006 | 08:29 AM
Tbone's Avatar
Default Re: (b19coupe)
Todd have you run the pro-3's in anything yet?( I cant remember) You want to try mine in something?
Old May 10, 2006 | 08:45 AM
b19coupe's Avatar
Default Re: (Tbone)
Have not tried the Pro3's-yet...
Old May 10, 2006 | 08:56 AM
Tbone's Avatar
Let me know if you want to.. i'll loan you mine..
Old May 10, 2006 | 09:08 AM
Thanks for doing this dyno comparison b19coupe. You've just made my cam purchasing even more difficult. LOL, I was dead set on the Skunk 2 PRO 1's, but now you have me looking at the Toda C's....
Only have a couple more questions....
Is there any other side effect from both of these cams?
I know about the Toda C's and the retainer to rocker wear issue. Do you experience this with your build?
Are they're any valvetrain issue's with the PRO 1's?
What do they both idle at and how is the idle? Smooth, lumpy?
Last question that's off topic, by any chance do you have the specs on the Toda C's and Toda C2's for comparision oh hand, if not I'll just search for them.
Duration ?
Lift ?
Opening BTDC ?
Closing - ABDC ?
Lobe Centreline ?
Thanks In Advance & thanks again for the dyno and sharing it with us
Old May 10, 2006 | 09:14 AM
No_Fear's Avatar
nice info,thank you
Old May 10, 2006 | 09:17 AM
b19coupe's Avatar
The Pro 1+ cams did not want to idle with the Toda C program-they were much more finicky, which leads me to believe that the primary and secondary lobes are bigger on the Skunk Cams. No retainer issues with the Toda C's, nor any issues at all, for that matter. I was told by Toda that the C2's have 5 degrees more duration than the C's.
C2's-(from Toda website)
IN 250 (11.0) - 300 (12.5) - 250 (11.0)
EX 250 (11.0) - 300 (12.5) - 250 (11.0)
(actually 260@1mm)
(the C's are 255@1mm)
Old May 10, 2006 | 01:41 PM
strsi's Avatar
wow, good info . thanks
Old May 10, 2006 | 02:43 PM
b19coupe's Avatar
Default Re: (FuLL ThroTTle RaCin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuLL ThroTTle RaCin &raquo;</TD></TR><TR><TD CLASS="quote">so ur assuming that the pro 1 primary and secondary are bigger than toda's 11mm primary and secondary?</TD></TR></TABLE>
It's more like an educated guess. I did not mic them, however.
Old May 10, 2006 | 02:50 PM
Viorent Grip! EG's Avatar
what are other specs on your motor?
