crank nose bolt
It's regular thread= leftly loosey, righty tighty. Easiest way without an air gun is by using a crankpulley holder, ie Honda crank pulley holder and i know some aftermarket companies make them or you can make one yourself if you can weld.
It's torqued to 181ft.lbs, Honda does this for a reason. If that bolt were to come loose say at 7500rpms(h22)=
Before installing apply motor oil to threads and torque to 181ft lbs.
http://www.thetoolwarehouse.net/shop/SP-60100.html
Modified by SteveoBA8 at 7:49 PM 5/9/2006
1995hondaEJ
15
Apr 20, 2012 04:23 AM
