Honda S2000 Honda S2000
2006 Air Filter - How to take off? - FAST PLZ !
Old May 9, 2006 | 02:09 PM
DineshD's Avatar
Default 2006 Air Filter - How to take off? - FAST PLZ !
I'm having some trouble taking the air filter off MY06 S. Can anyone help me out??
Old May 9, 2006 | 02:18 PM
Scotty B's Avatar
Default Re: 2006 Air Filter - How to take off? - FAST PLZ ! (DineshD)
Are you putting on an aftermarket intake? Are you trying to remove the Whole airbox, or just the filter? For the Filter...Just pop the clipse around the perimiter of the airbox.take off the top...and there it is.
Old May 9, 2006 | 02:19 PM
DineshD's Avatar
Default Re: 2006 Air Filter - How to take off? - FAST PLZ ! (Scotty B)
I've already takin of the airbox. The Filter is attached to something... never seen it like that before. Im puting on a K&N Filter....
Old May 9, 2006 | 02:41 PM
DineshD's Avatar
anyone plz......
Old May 9, 2006 | 03:04 PM
p nut's Avatar
Are you just putting in a drop-in K&N filter? The stock paper filter should just slide right out.
Old May 9, 2006 | 03:10 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: (P Nut)
I remember the s2ki guys sayin the intake and exhaust tracts were changed slightly. Makes sense, since the DBW takes up and extra chunk of space on the intake manifold. I don't know why they would change the filter mount... I'd need an 06 here to pop it's hood.
Old May 12, 2006 | 12:06 PM
One day...'s Avatar
there's a thin metal spring that wraps around the tip of the arm and hooks together to hold the cone filter in place. remove that and then the filter should slide right out.
Old May 12, 2006 | 12:39 PM
dkim48's Avatar
Default Re: 2006 Air Filter - How to take off? - FAST PLZ ! (SCIONtific)
mass air flow sensor?
Old May 12, 2006 | 12:40 PM
mykcuz's Avatar
i just put a k&n intake kit in yesturday. the filter slides off the intake tube, and the other end has a plastic peg that pushes into the bottom of thefilter box. there should be a whiteplastic loop attached to the end of the filter all u do is pull it straight up. it will just pop out. my s is a 2005...
Old May 12, 2006 | 06:18 PM
* B A N N E D *
Default Re: 2006 Air Filter - How to take off? - FAST PLZ ! (dkim48)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkim48 &raquo;</TD></TR><TR><TD CLASS="quote">mass air flow sensor?</TD></TR></TABLE>
Actually the car doesn't have one. I popped the hood of a friend's 06, it seems to have an IAT sensor right on the intake elbow, so intakes for 06+ should come with a bung for it.
And the bulky DBW throttle body.
skylinevo
Jul 7, 2006 08:47 AM
elpiar
Jun 2, 2006 07:30 AM
EJ8mike
Jul 6, 2005 02:38 PM
icefirezero
Jun 19, 2004 02:16 AM
accord ex
Feb 17, 2003 07:40 AM
