Da with LS motor Overheating
Old May 9, 2006 | 01:58 PM
Civicracer17's Avatar
Default Da with LS motor Overheating
For some reason when I'm on the Highway in Traffic my Engine temp goes all the way to H and once I start driving again it goes down to the middle... And Also my Antifreez resivior is missing Coolant every 4 days but the Radiator has Coolant in it
Old May 9, 2006 | 04:31 PM
92DAIntegraXSI's Avatar
Default Re: Da with LS motor Overheating (Civicracer17)
did you ever think to put the overflow back in maybe thats why your losing coolant do that be4 you blow your headgasket or crack the head/block
Old May 9, 2006 | 04:43 PM
DC2 Mang's Avatar
Default Re: Da with LS motor Overheating (92DAIntegraXSI)
thus usually has to do with the fan or the thermostat, check both
Old May 9, 2006 | 05:20 PM
Orangecivic251's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92DAIntegraXSI &raquo;</TD></TR><TR><TD CLASS="quote">did you ever think to put the overflow back in maybe thats why your losing coolant do that be4 you blow your headgasket or crack the head/block</TD></TR></TABLE> ok he is saying that coolant is missing from the resivoir every few days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMdc2lsVtec &raquo;</TD></TR><TR><TD CLASS="quote">thus usually has to do with the fan or the thermostat, check both </TD></TR></TABLE> he is correct check for a stuck thermostat and check to make sure your not losing it anywhere
Old May 9, 2006 | 05:52 PM
g2forlife's Avatar
yeah your therostat could be bad, had same problem but i ended up just getting a new radiator...
Old May 9, 2006 | 07:07 PM
Default Re: (g2forlife)
I replaced the Thermostat in March so it might be the fan..... I'll try that first
Old May 10, 2006 | 09:26 AM
DA is best's Avatar
i have that same problem with my 92 teg when im driving the temp is fine but when i stop it goes up , the problem was the fan shuts off when i stop then goes back on when i drive
ITR.#1446
Jul 28, 2008 07:11 PM
vroomboom
Honda Civic (2001 - 2005)
May 22, 2008 04:44 AM
soon2bdropped
Apr 6, 2007 11:34 AM
invisible
Mar 20, 2007 07:43 PM
DeDonDeRosa
Mar 21, 2006 10:37 AM
