removing ac
Old May 9, 2006 | 12:04 PM
dthug's Avatar
Default removing ac
i kno this has prolly been convered but i can't search for removing ac b/c ac is to short and if i type it all out it gives me something else.
my question is when i swapped in hte gsr into my hatch the ac was still connected to the motor i dont want it anymore how would i go about removing it ..its adding weight to the car that i dont need being that its not plugged in at all so i might as well remove it. is it difficult to do it?
Old May 9, 2006 | 12:10 PM
EG civic's Avatar
Default Re: removing ac (dthug)
Removing ac is not difficult, simply unbolt the bolts holding on the ac pump and comdenser. Un hook the ac pipes and allow the freon to leak out of the comdenser.
then remove the condeser and pipes.( which bolt to the pump) then u should be able to slide the condenser up and out, and the pump has 4 bolts holding it on just unbolt them and it will come right off.
Old May 9, 2006 | 12:41 PM
snatch's Avatar
Default Re: removing ac (EG civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG civic &raquo;</TD></TR><TR><TD CLASS="quote"> Un hook the ac pipes and allow the freon to leak out of the comdenser.
This isn't really the way you should do it. Freon into the atmosphere isn't good according to evironmental peeps. You should get it evacuated by a shop.
Old May 9, 2006 | 01:05 PM
schardbody's Avatar
he said its not hooked up anyways, so there isnt any freon in the system, he simply wants the components off the car, which means unbolting them.
Old May 9, 2006 | 02:18 PM
dthug's Avatar
Default Re: (schardbody)
how about the belt thats on it what do i do with that..i never really messed aroundwith puttin/taking still off a engine i just swapped it in as a whole
Old May 9, 2006 | 03:43 PM
schardbody's Avatar
cut the belt, you arent gonna use it again.
Old May 9, 2006 | 03:47 PM
dangle's Avatar
Remove 4 bolts holding the AC compressor, take off the belt (store it for later possible use or make your dog a new collar), and ta-da. It's going to be one hot *** summer. Haha. No worries though, mine's been removed too. Sacrifices must be made. And fyi, along with the few pounds you lost, you gained a pony or two. Less rotational mass frees up power. Good luck and happy wrenching.
Old May 9, 2006 | 04:08 PM
schardbody's Avatar
you wont see even 1hp by taking the belt off. if the clutch isnt engaged its like turning an idler pulley, which takes barely anything, surely not 1hp. and to take the belt off w/out cutting it you have to also take the alt and p/s belts off, and he doesnt know how to take the belt off in the first place i doubt he's willign to take them off just to keep a $8 belt.
Old May 9, 2006 | 04:15 PM
dthug's Avatar
so all i have to do is unblot it off and literally cut the belt??
that simple?
Old May 9, 2006 | 04:21 PM
schardbody's Avatar
yes
Kara ej8 civic
20
Aug 10, 2008 06:06 PM
99fbpem1
Oct 13, 2007 05:52 PM
mtownek9
Oct 9, 2007 06:30 PM
661rex89si
14
Oct 27, 2006 04:03 PM
