BIGGER THROTTLEBODY FROM H OR B SERIES ON A Z6.
Old May 9, 2006 | 11:16 AM
IVAN93EG's Avatar
Default BIGGER THROTTLEBODY FROM H OR B SERIES ON A Z6.
CAN I PUT A LARGER TB ON MY Z6 FROM AN H OR B SERIES. ANY VACUMM MODS AND WHAT ABOUT TB WIRE AND PORTING OF INTAKE MANNY?
Old May 9, 2006 | 11:18 AM
Out of every
Default Re: BIGGER THROTTLEBODY FROM H OR B SERIES ON A Z6. (IVAN93EG)
WHY ARE YOU YELLING AT US??!?!?!?!?!?!?!?!!
Honda Tool's Avatar
2010 Honda-Tech Poker champion
Well I would def be porting the intake to match the throttle body. Not much point in doing it if you dont.
pdiggitydogg's Avatar
See that button next to A and below Tab, labeled Caps Lock? Press it.
Yes, you can bolt a B series TB onto the d series IM. But, unless you bore the IM to match the size of the TB, youre really just wasting your time.
Old May 9, 2006 | 11:19 AM
IVAN93EG's Avatar
Default Re: BIGGER THROTTLEBODY FROM H OR B SERIES ON A Z6. (e gee two)
SORRY I ILL USE MY ONLINE VOICE NEXT TIME
Old May 9, 2006 | 11:21 AM
IVAN93EG's Avatar
ANY GAINS TO BE HAD FROM THIS? WHAT ABOUT VACUMM LINES AND CABLE?
Old May 9, 2006 | 11:54 AM
Dude...turn caps lock off or people will just keep bitching.
if you port match the intake manifold you will see minor gains...very minor. I have a b vtec tb on my y8 and all I see is a slight increase in mpg.
Everything lines up fine B:D
Old May 9, 2006 | 12:06 PM
HXvtec's Avatar
pointless. dont do it.
Old May 9, 2006 | 01:54 PM
IVAN93EG's Avatar
Default Re: BIGGER THROTTLEBODY FROM H OR B SERIES ON A Z6. (HXvtec)
what about h series t body?
Old May 9, 2006 | 02:51 PM
johnecon2001's Avatar
Same problem numbnutts.
Without port matching the IM you're not going to see any gains. EVEN if you go bigger.
Old May 9, 2006 | 03:08 PM
lonefuzzy79's Avatar
Why is it called yelling if it's all caps? I get it that it's annoying to read but why do we care? It's not really yelling, its just letters... Good info though, i was not aware a b-series tb will bolt to a d-series intake mani.
Old May 9, 2006 | 03:48 PM
HXvtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXvtec &raquo;</TD></TR><TR><TD CLASS="quote">pointless. dont do it. </TD></TR></TABLE>
cpl rampage
23
Apr 22, 2009 03:44 AM
RipSiTurboHatch
Oct 27, 2005 12:09 PM
boosted k20
Jan 10, 2005 01:38 PM
s0ulless
Nov 25, 2004 12:55 PM
freezerburnv2
Sep 25, 2003 05:15 PM
