Car won't start. Constant clicking and beeping...clock dims intermittently?!
Old May 9, 2006 | 08:03 AM
TheHooded_Mike's Avatar
Default Car won't start. Constant clicking and beeping...clock dims intermittently?!
My sister's Integra won't start. She left her car for like 3 hours, and when she came back it wouldn't start but would crank. Now, I tried jump-starting it today and it won't even turn over...not even a click. But, there is a constant clicking (even with the keys out) coming from under the instrument panel. The clock on the dash also dims intermittently; I'm assuming that this is an indicator for something, but I just don't know what. I tried tapping on the starter with a hammer, too (does this sound like a bad starter to you?) The thing that gets me is that yesterday it would turn over fine, but was kind of rough and shook the car a bit. That made me think something with the timing. I'm really not sure though...any ideas? Thanks.
Old May 9, 2006 | 04:33 PM
Default Re: Car won't start. Constant clicking and beeping...clock dims intermittently?! (TheHooded_Mike)
Help please! Yesterday, even though it wouldn't start it at least turned over...now there isn't even a click.
Old May 9, 2006 | 04:34 PM
Lan's Avatar
Lan
It is an aftermarket alarm. Do you have the alarm button on the keychain?
Old May 9, 2006 | 06:48 PM
Default Re: Car won't start. Constant clicking and beeping...clock dims intermittently?! (Lan)
Holy **** you're right...my sister bought the car from my friend and something was up with the alarm so we just ripped out the horn and she took the remote off of her keychain. There's a switch installed under the dash to toggle the alarm on and off, and I think I hit it! Wow, thanks a lot for that info...now the problem is that it turns over but won't start. It feels really rough too...like shakes the car pretty badly. That made me think the timing was off like I said, but what do I know. Any more ideas? Again Lan, thanks a lot.
Old May 10, 2006 | 07:08 AM
What would make it shake so bad when trying to start?
Old May 10, 2006 | 07:27 AM
Lan's Avatar
Lan
Are you getting fuel and spark? Could be shaking due to old motor mounts, you said you hit the toggle switch, but the car still will not start?
Old May 10, 2006 | 09:20 AM
It already wouldn't start, then I hit the toggle switch and it wouldn't even turn over. Now I'm back to it not starting but turning over and shaking pretty bad.
Old May 11, 2006 | 12:57 PM
Seems really choppy when it turns over, trying a new cap and rotor.
Old May 13, 2006 | 12:20 PM
New cap, rotor, and spark plugs and no luck. Fuel pump primes...what are some obvious things to check. I mean, the car only sat a few hours before it wouldn't start again. Has to be something simple. Help!
Old May 13, 2006 | 01:11 PM
Acura_I-RS's Avatar
check your grounds man, especially the one on the thermostat housing. i had about the same problem.. hope that helps.
Old May 13, 2006 | 02:24 PM
cosmokramer's Avatar
have you checked the battery?? this sounds like an extremly dead battery. Try checking if there is water in the battery cells, if there is not....then add some and charge the battery for an extended period of time. My car had the same problem before and this worked.
Old May 13, 2006 | 05:32 PM
antiJDM's Avatar
check all your battery connections and grounds, even the connection on the alternator. if the car still won't start, try jumping it, and keeping the jumper cables on (running her car off another running car). if after you pull the jumper cables off and it dies, it could mean that you have a bad alternator. her car could still run with a dead battery, but if the alternator is bad as well then it wont run at all. I had a similar problem with my first car where my alternator went out but the battery still had enough power to turn the car over - but not start it. hope this helps.
Old May 14, 2006 | 04:33 PM
Default Re: (antiJDM)
I haven't had a nice day or a day off of work to look at it some work...it's gonna turn out being a ground I'm sure. Thanks for all the help.
Old May 19, 2006 | 02:33 PM
Default Re: (TheHooded_Mike)
The car is getting fuel for sure, and good compression, and when I removed the distributor and manually turned it, it appeared to be activating the injectors.
Removed spark plugs and grounded to the head - no apparent spark. Like I said new plugs, cap and rotor.
Note: Engine seems to be cranking faster than usual. What do I do now? Seems like a no-spark issue. Is there a sensor that is needed to make spark?
Old May 19, 2006 | 02:39 PM
LordAphotic's Avatar
rip out that alarm system. restore the wiring under the dash.
Old May 19, 2006 | 03:24 PM
Mt3c's Avatar
25 Year Member
iginition coil. ignitor coil. do you have a multimeter? check those if you're getting no spark.
Old May 19, 2006 | 03:50 PM
Default Re: (Mt3c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mt3c &raquo;</TD></TR><TR><TD CLASS="quote">iginition coil. ignitor coil. do you have a multimeter? check those if you're getting no spark.</TD></TR></TABLE>
Ya, that's my next step...my friend is bringing his over tmr. Thanks.
loayo
11
Mar 12, 2012 12:49 PM
OldskoojdmDA9
Feb 1, 2010 04:13 PM
everlight44
Feb 7, 2009 11:35 AM
lowblazin
Nov 25, 2003 10:00 AM
