AUTO TO MANUAL CONVERSION...
Old May 9, 2006 | 07:40 AM
RTCdominicano's Avatar
Default AUTO TO MANUAL CONVERSION...
I JUST FINISHED DOING A SEARCH BUT COULDNT FIND ANYTHING MAYBE SOME OF U CAN SHED SOME LIGHT ON THIS FOR ME....IM GETTIN A 93 CX HATCHBACK....BUT ITS AUTOMATIC..I HAVE RIGHT NOW A 92 VX HATCHBACK AND ITS MANUAL....THE ONLY PROBLEM WITH THE HATCH I HAVE NOW IS THAT IT WAS CRASHED BAD IN THE FRONT AND THEY HAD FIXED IT BUT IT WASENT A GOOD JOB..AND IS HAS NO A/C OR RADIO AND THE 93 DOES.....SO WHAT I WANTED TO DO IS CONVERT THE 93 TO MANUAL USING THE PARTS OF MY 92...ANY IDEA WHERE TO START WHAT DO I NEED??ANYTHING WILL HELP...THANKS...
P.S. I WANT TO USE THE ENGINE AND TRANNY FROM THE 92 HATCH
Old May 9, 2006 | 09:36 AM
joker4096's Avatar
Default Re: AUTO TO MANUAL CONVERSION... (RTCdominicano)
everything shoudl bolt right up to eachother. just u will have to get an auto to manual top tranny mount
Old May 9, 2006 | 10:25 AM
rabius's Avatar
pass. side mount has to be moved back (metal part on the frame rail), the shifter hole has to be cut out for the manual shifter to fit in the automatic car, and dont forget to change the axles out, auto tranny axles are a different length. everything else should be bolt and run. dont forget to splice the two big black wires under the shifter in the auto car together, or it will never start. and swap the ECU out too.
Old May 9, 2006 | 11:06 AM
tatmark1's Avatar
when searching search archived content rater than recent.
spend a hundred bucks on a conversion mount instead of changing frame bracket. and you dont have to cut a hole for the shifter. at least i didnt
Old May 9, 2006 | 12:22 PM
philosofy1's Avatar
Default Re: (tatmark1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tatmark1 &raquo;</TD></TR><TR><TD CLASS="quote">when searching search archived content rater than recent.
spend a hundred bucks on a conversion mount instead of changing frame bracket. and you dont have to cut a hole for the shifter. at least i didnt</TD></TR></TABLE>
agreed, it is probably safer just to spend the $100 for the mount versus replacing it w/ a manual one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rabius &raquo;</TD></TR><TR><TD CLASS="quote">pass. side mount has to be moved back (metal part on the frame rail), the shifter hole has to be cut out for the manual shifter to fit in the automatic car, and dont forget to change the axles out, auto tranny axles are a different length. everything else should be bolt and run. dont forget to splice the two big black wires under the shifter in the auto car together, or it will never start. and swap the ECU out too.</TD></TR></TABLE>
also you don't have to push back any bracket or cut out a hole for the shifter
Old May 9, 2006 | 12:58 PM
MR_Ek4's Avatar
Default Re: (philosofy1)
Also you will need the clutch fluid reservoir and will have to run the line to the clutch, Good Luck
Old May 9, 2006 | 01:42 PM
DestructoEH's Avatar
Default Re: (rabius)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rabius &raquo;</TD></TR><TR><TD CLASS="quote">and dont forget to change the axles out, auto tranny axles are a different length.</TD></TR></TABLE>
I thought all 92-00 D-series axles were the same? Is there really a length difference?
Old May 9, 2006 | 01:44 PM
SOHC4life 96's Avatar
Default Re: (DestructoEH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DestructoEH &raquo;</TD></TR><TR><TD CLASS="quote">I thought all 92-00 D-series axles were the same? Is there really a length difference? </TD></TR></TABLE>
They are. If you don't believe me, then why is my car running right now? I'm using my auto axles in my converted manual civic. With no adverse side effects might I add.
Old May 9, 2006 | 01:50 PM
Default Re: (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">
They are. If you don't believe me, then why is my car running right now? I'm using my auto axles in my converted manual civic. With no adverse side effects might I add.</TD></TR></TABLE>
Kick ***. I had my auto axles rebuilt like 8 months ago and they're in great shape. I was hoping I wouldn't have to crap out and buy more when I finish getting my d15b built for the auto-manual swap. Thanks for clarifying that.
Old May 9, 2006 | 06:20 PM
joker4096's Avatar
there is a full walkthrough on how to do the swaps for eks and egs in the faqs at the top of the page. check em out
Old May 10, 2006 | 07:14 AM
thansk for the help guys...
Old May 10, 2006 | 11:49 PM
chris00tt's Avatar
I've seen some people say the manual intermediate shaft is needed for this swap. Others have said the automatic axles worked fine without any problems. What is the consensus here? This is for an EG civic by the way, 94 DX.
Old May 11, 2006 | 04:14 AM
stackz's Avatar
at the jetties fishin'
Community Builder
Default Re: AUTO TO MANUAL CONVERSION... (joker4096)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joker4096 &raquo;</TD></TR><TR><TD CLASS="quote">there is a full walkthrough on how to do the swaps for eks and egs in the faqs at the top of the page. check em out </TD></TR></TABLE>
the one I found for the eg auto/manual swap is missing all the pictures and like half the people here....I learn more from pictures than reading someone's attempt at a description...
JDM-ish
Mar 15, 2010 06:02 PM
EGandDArida
Jul 30, 2008 01:41 PM
hondapower321
Jan 26, 2007 06:53 PM
93FastLs
Jul 28, 2005 11:02 PM
petarr
Jan 21, 2005 10:21 AM
