Correctly remove the bottom grill on a 96-98 civic
Anybody know how to correctly remove the grille on the bottom so it looks good, i know you use a dremel but i want to make sure it is done the right way so it leaves no unfinished points?
pull your bumper off, look behind it at where the grill attaches, cut all those, grind em smooth and your done. Its not that hard, nobody can really give you exact instructions, but if you just look at it you'll figure it out.
but my car is white, if i cut it off and grind it down there will be black marks where it used to attach and that will look so tacky
JDM KID 510
29
Apr 26, 2006 07:15 PM
