need help on 97 hatch
Old May 9, 2006 | 06:42 AM
existanzcivicb20's Avatar
Default need help on 97 hatch
hey guys I have a 97 hatch with a b20 obd2 and the problem is this when im driving every thing
is fine but when im coming to a stop and throw it in neutral the idle stay at 2000 rpm then when
the car come to a complete stop the idle goes back to normal but only when I am completely
stoped why is this
Old May 9, 2006 | 07:30 AM
Default Re: need help on 97 hatch (existanzcivicb20)
any one
Old May 9, 2006 | 07:44 AM
Si_chRis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by existanzcivicb20 &raquo;</TD></TR><TR><TD CLASS="quote"> hey guys I have a 97 hatch with a b20 obd2 and the problem is this when im driving every thing
stoped why is this </TD></TR></TABLE>
i have a 2000 si and the same thing happened to me . my throttle body was dirty and it caused my car to run like that cuz of the t body spring. it caused the t body to not shut completly but once i cleaned it, the t body function perfect. also adjust ur throttle cable. and check ur spark plugs.
Old May 9, 2006 | 08:15 AM
Default Re: need help on 97 hatch (JDMaLLDAy050)
thanks Ill do that as soon as I get home thanks a lot
Old May 9, 2006 | 09:30 AM
any one else have any suggestions were I can look for my problem
Old May 9, 2006 | 11:01 AM
how would you check to see if you have a bad EACV
Old May 16, 2006 | 10:30 AM
rockin_remz's Avatar
also check your idle air control valve. sometimes that will cause the rpm's to stick like that. if its dirty go get some carb. cleaner and spray it clean. be careful with it though its a fairly expensive part.
Old May 16, 2006 | 03:40 PM
NVturbo's Avatar
O.G. triple O.G.
Is your car throwing any CELs?
existanzcivicb20
May 9, 2006 01:37 PM
existanzcivicb20
May 9, 2006 10:58 AM
sikwitit
Nov 8, 2005 02:50 PM
Too_Funny
Nov 13, 2003 01:53 AM
