Does anyone have a link or info on how to pull the OEM head unit in a 5th gen?
Old May 9, 2006 | 06:33 AM
justint's Avatar
Default Does anyone have a link or info on how to pull the OEM head unit in a 5th gen?
Do I have to take apart the whole dash to pull the old unit and install an aftermarket? I can't seem to find a link to directions for this car.
Old May 9, 2006 | 07:15 AM
Hondapreludeg's Avatar
All you have to do is pry the trim piece around the radio off with a flathead of just pull it off. Then take the four screws out to pull the head unit out.
Old May 9, 2006 | 09:54 AM
smo0th's Avatar
Default Re: Does anyone have a link or info on how to pull the OEM head unit in a 5th gen? (justint)
I was wondering the same thing, thanks ^
Old May 9, 2006 | 10:04 AM
maks's Avatar
Default Re: (Hondapreludeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondapreludeg &raquo;</TD></TR><TR><TD CLASS="quote">All you have to do is pry the trim piece around the radio off with a flathead of just pull it off. Then take the four screws out to pull the head unit out.</TD></TR></TABLE>
Plastic ruler, or similar works great to pry it up (avoid using something rough like a screwdriver, as it can leave scratches)
Old May 9, 2006 | 01:28 PM
aderino4's Avatar
Default Re: (maks)
Even easier, just put 8 fingers underneath the top piece (above the A/C control or climate control) There should be a gap between the piece and the dash and you should be able to have a good grip of the piece and then just pull it out.
No scratch no problem. Then there are another 4 screwdrivers to take the whole assembly and another 2 to 4 to take out the head unit itself.
92civic_si
Apr 11, 2007 01:01 PM
93allmotorcoupe
Audio / Security / Video
Mar 17, 2006 08:43 AM
c_kubie
Jul 8, 2005 03:09 PM
efracer
Dec 25, 2004 10:12 AM
TKirk
Oct 8, 2003 11:25 PM
