CLUTCH Problem...... I think??????!
Old May 9, 2006 | 05:44 AM
alltech_hybrid's Avatar
Default CLUTCH Problem...... I think??????!
OK i have an 01 Suzuki GSXR 600... this is my third bike and first one i am having problems with as far as the clutch goes... It unloads or slips in 6th and 5th gear on the HIGHWAY every now and then... scares the SH*T outta me cuz it just seems to lose grip and jerk back and die outta no where.... cruising at a steady speed and steady rpm. At first i thought it was my chain because it was loose but i tightened it and it still does it... I think my clutch is starting to slip but just wanted to see what some of the other riders thought... is it time for a new clutch? The previous owner used to wheelie on it alot so i know i should prolly replace it anyway but is this my problem
Old May 9, 2006 | 05:46 AM
Sijray21's Avatar
how many miles are on it?
when did you buy it?
Old May 9, 2006 | 05:47 AM
Default Re: (Sijray21)
it has aprox 18,000... only had it for about 5 months
Old May 9, 2006 | 05:53 AM
Sijray21's Avatar
i would think that with that amount of mileage it would be b/c of that, but are you having any issues with hard acceleration in the lower gears?
Old May 9, 2006 | 05:56 AM
no not at all! thats the thing that gets me... daily drivin on the streets SEEMS to be fine... the bike is still really torqey and accelerates fine... its just on the highway when im at a steady speed around 70-80 it will just take a sh*t! could it be my chain or the sprocket????????
Old May 9, 2006 | 06:32 AM
TXcivic96's Avatar
Default Re: (alltech_hybrid)
not the chain or sprockets, you would hear a clunking sound and probably notice broke teeth on the sprocket. Usually the rule on a bike (so i'm told) Is once a clutch slips on a bike (with out you sliping it) It's pretty much done with because it's only going to get worse. The same think happened to my firends 99 750, he could still clutch up wheelies in 2nd and 3rd but even just going down the highway and would try to accelerate in 5th or 6th the clutch would slip some. How old are your chain and sprockets also. If you have more than 8k on them I would go ahead and change those out also.
Chris.
Edit: Also check your clutch cable, make sure it's lubed and isn't hanging up.
Old May 9, 2006 | 06:37 AM
Default Re: (jdmboostedlude)
good info man! thanks... the chaing and sprockets are all oem so im guessing they were never changed.. and now that you mention it when my chain was lose i noticed metal shavings above the shifter near the spring.. maybe i tore up some teeth on the sprocket???
looks like i will be replacing and UPGRADING my chain, sprocket, and clutch then.... any recommendations???
Old May 9, 2006 | 06:44 AM
TXcivic96's Avatar
I'm using renthal sprockets, and a EK chain. As for a clutch I reccomend Hinson Racing. Or DP.
As for gears I went up 5 in the rear and 1 down in the front. I only reccomend using renthal because of what I've seen and heard from a few different people. Unless of course your stunting then I would say vortex, but not for everyday riding. Also the chain, make sure it's a rivet link, My friend had a master link brek on him and hit his calf, it took alot of stitches to say the lease. And as for brand of chain make sure it's an o-ring. DID ERV2 or ERV3, or the EK racing chain are both great chains.
Old May 9, 2006 | 06:53 AM
alltech.magoo's Avatar
damn good info.. hope thats get your bike to stop slipping in high gear.. upgrade it all Ant new clutch,chain, and sprocket while your there.
Old May 9, 2006 | 06:56 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboostedlude &raquo;</TD></TR><TR><TD CLASS="quote">I'm using renthal sprockets, and a EK chain. As for a clutch I reccomend Hinson Racing. Or DP.
As for gears I went up 5 in the rear and 1 down in the front. I only reccomend using renthal because of what I've seen and heard from a few different people. Unless of course your stunting then I would say vortex, but not for everyday riding. Also the chain, make sure it's a rivet link, My friend had a master link brek on him and hit his calf, it took alot of stitches to say the lease. And as for brand of chain make sure it's an o-ring. DID ERV2 or ERV3, or the EK racing chain are both great chains.</TD></TR></TABLE>
thanks bro... any links to this stuff? im new to the bike upgrading world.. and no im not stunting.. im actually goin to lower the bike as well so any tips would be great .... keeping in mind im a college student on a budget! so i need the best bang for my buck
Old May 9, 2006 | 10:42 AM
anyone else?
Old May 9, 2006 | 10:51 AM
4-ageTOg63's Avatar
Sounds like the clutch is going....
Old May 9, 2006 | 02:19 PM
rdblckSV650S's Avatar
Default Re: (4-ageTOg63)
i know this doesn't fit with everyone's diagnosis, and i'm by no means discrediting their ideas, but one time my F4i did this to me with only 7000 miles on the clock. It was a long ride (about 2 hours) and the clutch started slipping when i would throttle harder in 5 or 6. I got home, changed the oil (changed brands too, i have no idea what was in there previously) and i haven't had the problem since. Just wondering if the oil could possibly be a factor.
Old May 9, 2006 | 02:44 PM
MSchu's Avatar
My Name is Nobody
Default Re: (slvrblckf4i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slvrblckf4i &raquo;</TD></TR><TR><TD CLASS="quote">i know this doesn't fit with everyone's diagnosis, and i'm by no means discrediting their ideas, but one time my F4i did this to me with only 7000 miles on the clock. It was a long ride (about 2 hours) and the clutch started slipping when i would throttle harder in 5 or 6. I got home, changed the oil (changed brands too, i have no idea what was in there previously) and i haven't had the problem since. Just wondering if the oil could possibly be a factor.</TD></TR></TABLE>
Yes, but his symptoms sound exactly like clutch slippage from wear... As long as the revs are rising when you experience the problem
Old May 10, 2006 | 04:36 AM
you know i thought the same thing because its about time for an oil change but i dunno if bad oil would really cause that kind of problem... thanks for all the info guys! keep em coming!
Old May 12, 2006 | 06:51 AM
do you guys think it could be my sprocket? i see metal shavings so could some of the teeth possibly be worn out??
alexsneesby
Aug 18, 2010 12:11 PM
u n v kenny
Honda Motorcycles
Aug 15, 2005 11:18 AM
ijjz
Apr 14, 2003 06:08 PM
