D16z6 intake manifold on a D15B7 engine?
The z6 mani will bolt on from what I have read, but I'm curious if I need to upgrade anything else like fuel injectors for the z6, fuel rail, throttle body..
Or is it all interchangeable with each other?
Thanks for any help.
no real reason....something to do....i cant imagine it would make any noticeable difference...maybe a little more air flow....
i have a perfectly clean d16z6 intake manifold sitting around, thought it would be a fun quick task....
It will help out more than likely, I know swapping a Y8 manifold onto a Y7 head helped me quite a bit. I don't think you need to swap the injectors, fuel rail, etc. I used all my Y7 stuff and it worked fine. I would presume the B7 stuff would work on the Z6 as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** »</TD></TR><TR><TD CLASS="quote">It will help out more than likely, I know swapping a Y8 manifold onto a Y7 head helped me quite a bit. I don't think you need to swap the injectors, fuel rail, etc. I used all my Y7 stuff and it worked fine. I would presume the B7 stuff would work on the Z6 as well. </TD></TR></TABLE>
Right on. Thanks!
Right on. Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody »</TD></TR><TR><TD CLASS="quote">its a direct swap, use either your stuff or the z6 stuff. not going to make a noticeable differance though.</TD></TR></TABLE>
I figured as much.
I figured as much.
PrettyMuchBoned
24
Apr 16, 2014 11:48 AM
shawnperolis
11
Sep 2, 2010 11:42 AM
Educator
Nov 25, 2008 07:58 AM
purple98ek
Sep 24, 2005 08:25 PM
