Bigger brake master cylinder swap?
Old Apr 10, 2002 | 02:43 PM
TurboIntegra's Avatar
Default Bigger brake master cylinder swap?
I have access to BOTH:
00 SI master cylinder and
98 Acura CL master cylinder (supposedly same as Type R?).
Would either of these be benifecial to my CX hatch? If so which would be better?
Old Apr 10, 2002 | 05:49 PM
Default Re: Bigger brake master cylinder swap? (TurboIntegra)
anybody?
Old Apr 10, 2002 | 10:28 PM
Solo2Vtec's Avatar
I would like to know also. I have a 2000 Civic Si Master in the box but not sure if its better than what I already have on my 92 si? Mines 15/16th and the new Si one says 7/8th? Is the new 2000 Civic Si Master Cylinder bettet than the stock one I have?
Old Apr 11, 2002 | 09:39 AM
Trey's Avatar
25 Year Member
Default Re: Bigger brake master cylinder swap? (Solo2Vtec)
The ONLY difference a bigger bore MC does is take less pressure to make the brakes engage.
CX brake pedel needs to be pushed a little further to engage the brakes.
ITR, Si takes less pedel pressure to engage the brakes.
Get it?
Also, a 99-00 Si MC on a 92-95 Civic means you'll have to bend the hard lines to line up to the newer MC. Not worth it. Get a 94-95 integra MC since the hard lines are in the same place.
HTH,
Old Apr 11, 2002 | 09:58 AM
Solo2Vtec's Avatar
Default Re: Bigger brake master cylinder swap? (Trey)
Thanks Trey
Old Apr 11, 2002 | 11:19 AM
B19CivicHB's Avatar
More specifically, get an integra RS master cylinder. Since they didnt have ABS it is a perfect plug and play part for your hatch.
motore
Suspension & Brakes
26
Jan 9, 2006 06:23 AM
ek9junky
Apr 4, 2005 09:20 PM
adrian1281
Aug 23, 2003 09:43 PM
