idle backfiring and brake problems
Old May 8, 2006 | 06:57 PM
C1CRX's Avatar
Traffic signal tech
Default idle backfiring and brake problems
like topic says im having problems with my idle it gets really low about 5 minutes after start up and when i let off the gas there is some really really loud backfires and i can even hear backfires at idle i was thinking it might be my iavc or whatever the acronym for it is but im not sure im not throwing any codes im also thinking i might have air in my coolant casue this problem started about 1 month ago but i want to see all of your suggestions my set up is a d16y8 in a 91 crx still obd0 running ona vtec contoller and the brake problme is my pedal starts going all the way down when im at a light or stop sign while pressing the brake so if u guys can gimme some suggestions or ideas i would really appriciate it
Old May 8, 2006 | 07:02 PM
SFlCrx's Avatar
if u think you have air in the coolant do a cylinder leak down test, as for brakes are they stock disc up front and drums in the rear, also are u leaking brake fuild? are the pads low
Old May 8, 2006 | 07:06 PM
C1CRX's Avatar
Traffic signal tech
Default Re: (SFlCrx)
its a 91 SI so its discs on front and back i dont believe im leaking brake fluid and the pads are about 6 months old and il try to get the cylinder leak down test done
Old May 8, 2006 | 07:10 PM
SIred91's Avatar
Rainman
Default Re: (lvcrx)
your brake problem is your power booster, more so if it does it the hotter it is outside or under hood.....when the car is hotter or its hotter outside it does it worse doesnt it..........brake booster dude,
trust me.
Old May 8, 2006 | 07:54 PM
SFlCrx's Avatar
check the vacuum hoses going to the booster before u start buying parts
Old May 9, 2006 | 06:10 PM
C1CRX's Avatar
Traffic signal tech
bump any mor suggestions ??? please
Old May 9, 2006 | 07:42 PM
Targa250R's Avatar
be professional
Default Re: idle backfiring and brake problems (lvcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lvcrx &raquo;</TD></TR><TR><TD CLASS="quote">the brake problme is my pedal starts going all the way down when im at a light or stop sign while pressing the brake so if u guys can gimme some suggestions or ideas i would really appriciate it</TD></TR></TABLE>
Your brake master cylinder is bad. Replace the master cylinder.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">your brake problem is your power booster, more so if it does it the hotter it is outside or under hood.....when the car is hotter or its hotter outside it does it worse doesnt it..........brake booster dude,
trust me.</TD></TR></TABLE>
No it isn't. A faulty booster will make the pedal get harder, not sink to the floor.
Old May 9, 2006 | 07:43 PM
C1CRX's Avatar
Traffic signal tech
Default Re: idle backfiring and brake problems (Targa250R)
thanx alot any suggestions on the idle problem maybe the iacv?
Old May 10, 2006 | 08:08 AM
SIred91's Avatar
Rainman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
No it isn't. A faulty booster will make the pedal get harder, not sink to the floor.</TD></TR></TABLE>
so two of the three hondas that i own that did that and were fixed by new brake boosters lied to me?
Old May 10, 2006 | 12:21 PM
C1CRX's Avatar
Traffic signal tech
BUMP
Old May 11, 2006 | 08:44 PM
C1CRX's Avatar
Traffic signal tech
BUMP someone help me with my idle problem
Old May 11, 2006 | 10:57 PM
project 2two9's Avatar
check ur distributor and fireing order... and your brakes, either u have a leak in ur line or you need to rebleed them asap
Old May 17, 2006 | 11:23 AM
C1CRX's Avatar
Traffic signal tech
BUMP moer suggestions please
Redprelude98
25
Nov 30, 2014 02:15 PM
Cambocheen!
Mar 23, 2009 12:09 PM
RACEPAK
Nov 23, 2006 01:33 PM
SwampThing
Sep 12, 2005 02:41 PM
smithbling
Mar 13, 2003 03:49 PM
