couple noises
Old May 8, 2006 | 05:57 PM
DelSolMarine's Avatar
Default couple noises
when i start my car after its been sitting for a while it makes a loud screetching noise for like a couple seconds... my guess is that its the belt its a B18C swap about 2 months that ive had it
also if i hear clicking when i turn left that means it the passenger side axle right?
also after i and say im rolling to a stop light to stop and i push in the cluth and put the car into neutral the car max a whining noise as its slowing down is that the clutch?
Old May 8, 2006 | 06:13 PM
Default Re: couple noises (DelSolMarine)
bump
Old May 8, 2006 | 06:27 PM
InsertRacialSlur's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolMarine &raquo;</TD></TR><TR><TD CLASS="quote">when i start my car after its been sitting for a while it makes a loud screetching noise for like a couple seconds... my guess is that its the belt its a B18C swap about 2 months that ive had it
also after i and say im rolling to a stop light to stop and i push in the cluth and put the car into neutral the car max a whining noise as its slowing down is that the clutch?</TD></TR></TABLE>
That screeching noise is the water from the condensation getting worked off the belts.
Not sure about the clicking.
I hear the whine in my car, too - I'm not sure what it is, but I think it's normal.
Old May 8, 2006 | 06:34 PM
Default Re: couple noises (TypeRWanter)
awesome thanks anyone know bout the clicking?
Old May 8, 2006 | 06:51 PM
FalkenSiR's Avatar
Clicking is most likely your axles, "whinning" could be your clutch cylinder. Does it happen every time u push the clutch?
The condensation from the belts is going to go away, don't worry. My car sat for a while and it did that too (same with your motor probably). Mine went away after a month or two.
Old May 8, 2006 | 07:13 PM
Default Re: couple noises (fast95eg9)
when i push it in and hold it in when im coasting to like a stop and it clicks only when i turn left
91CTR
Oct 16, 2018 11:16 AM
A is 4 PiMp
Sep 29, 2006 07:29 PM
totsie7944
Sep 21, 2004 04:58 PM
shipsaeki
May 28, 2003 07:13 PM
Striker
Feb 1, 2002 02:56 PM
