Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Help finding Issue with car
Old Sep 20, 2018 | 09:22 AM
91CTR's Avatar
Default Help finding Issue with car
The other day I was running AutoX in my car when it suddenly began to make noises after a run. The noise sounds like a clunking noise coming from under the hood. The sound seems to match the speed the car is going, but it only happens when in neutral. When in drive, the noise gets better and almost goes away, but as soon as it goes in neutral, the clunking noise starts getting louder. To me it sounds like an axle needs replacing, but I read that it would cause noises when turning or in drive under acceleration, not in neutral. I know the details are pretty vague, but I was hoping someone else had this issue so they can point me in the right direction. I don't want to replace an axle only to find out its a larger transmission issue.
Also, car in question is a 91 civic hatchback DX w/ a B18c Type R swap.
Old Sep 20, 2018 | 09:52 AM
sjg88's Avatar
5 Year Member
Default Re: Help finding Issue with car
does the noise go away or change when you press the clutch pedal in?
Old Sep 20, 2018 | 10:43 AM
91CTR's Avatar
If i'm in gear and driving, then its not so bad. Once I hit the clutch and go into neutral, the clunking noise comes back.
Old Sep 20, 2018 | 01:47 PM
90civichbsi's Avatar
Does it make the noise in neutral with the clutch released? Or only when the clutch is pressed in?
If it's only with the clutch pressed in I would think it's your throw out bearing.
Old Sep 21, 2018 | 07:28 AM
sjg88's Avatar
5 Year Member
input shaft bearing sounds like it may be on its way out
Old Sep 21, 2018 | 01:21 PM
dirty19's Avatar
Ridin Dirty in Cali
Clutch spring broken???
Time to pull the tranny and look.
Old Oct 13, 2018 | 10:15 PM
Svg21's Avatar
I think you should check the clutch spring...
Old Oct 16, 2018 | 11:16 AM
garf's Avatar
Sound anything like this? I have been having what sounds like the same issue with my b16a2. It's bone stock.
EK4DoorGuy
Oct 30, 2013 04:24 AM
wolf10851
Jun 26, 2006 11:00 AM
CRX_Control
Jan 13, 2005 09:40 AM
jennabee
Nov 30, 2004 07:58 AM
