Super duper rich....
Old May 8, 2006 | 05:34 PM
90jdmcrxdude's Avatar
Default Super duper rich....
I did a b16a swap into my 90 crx dx and it is running unbelievably rich (like a coating of black stuff on the back of my car) when I first take off the car is real sluggish until above 4000 rpm then its fine after that. I'm running a chipped PR3 ecu and I have a virgin PW0 ecu. The only code I'm getting are for knock sensor. They both do the same thing. I have changed the O2 sensors and the injectors however it is the same problem. It almost seems like the ecu is giving a constant pulse to the injectors putting to much gas. It hits Vtec fine and other than the rich problem its great. I was thinking maybe it is the TPS sensor because when the car was idleing I unplugged it and there was no change in the cars idle or anything, so I switched the 2 outside wires on the tps plug and no change then either. I need to figure out whats wrong b4 gas goes above $5 a gallon because its killing me right now I only think I'm getting like 10 mpg. Can somebody help me without telling me to go buy an Vacf or hondata or anything like that I just need to know WTF is wrong.
Old May 8, 2006 | 05:44 PM
Suck my DX's Avatar
Default Re: Super duper rich.... (90jdmcrxdude)
did u mess with the fuel map when u chipped it?
Old May 8, 2006 | 06:01 PM
Default Re: Super duper rich.... (Suck my DX)
Its a spoon chip vtec 5500 rev lim 8500 and no speed govener that I put in, however I have a non chipped ecu which does the same thing. my mechanic couldnt figure it out, however he didnt spend much time on it bcuz he was really busy
90jdmcrxdude
May 13, 2006 02:24 PM
520_Motorsports
Aug 10, 2004 07:40 PM
