need to pass smog
Old May 8, 2006 | 04:47 PM
dragracer1492's Avatar
Default need to pass smog
alright guys heres the deal, i needa pass smog as i only have about 2 more weeks too. I changed my oil, oil filter, spark plugs, timing belt, water pump, alternator belt, a/c belt, and head gasket and still blowing some white smoke when i start reving it high. I dont know if this thing will be able to pass or not its a 94 civic b18b7 200,000 miles. Anyone know any people in the san bernardino/909 area that will help me out for some money and maybe some other stuff. Im good with computers please i need help!!!!! i dont have really any money right now im flat broke and dont get paid till another 2 weeks, i alrdy wasted my check tryin to fix this crap help!
Old May 8, 2006 | 04:56 PM
Jedi_Sol's Avatar
Default Re: need to pass smog (dragracer1492)
Request an extension.
Old May 8, 2006 | 05:23 PM
blueshark's Avatar
Post your results! High NOx, High H/C, High C/O? If I know this maybe I can help.
Old May 8, 2006 | 06:00 PM
bstronger's Avatar
yeahhh my car doesnt pass smog either and i called the dmv and they said that you can get an extension and they will give you as much time as you need so that you can get it to pass but call them and ask cause that will give you time to find the problem.
Old May 8, 2006 | 06:03 PM
professor poon's Avatar
Yup, extension's the way to go. Just go down there and sound pathetic... It worked for me twice in a row! four month extension, ohhhh yeah.
Old May 8, 2006 | 07:53 PM
Default Re: (professor poon)
so extensions... how do i do this? like do i go to a smog test and when i fail i go to the dmv and ask for a extension and say beucase of money problems so i dont have the money right now to do it, and ask for lke a extra 2 months? thanks
Old May 8, 2006 | 07:59 PM
Jedi_Sol's Avatar
Default Re: (dragracer1492)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragracer1492 &raquo;</TD></TR><TR><TD CLASS="quote">so extensions... how do i do this? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bstronger &raquo;</TD></TR><TR><TD CLASS="quote"> i called the dmv ... but call them and ask </TD></TR></TABLE>
Old May 8, 2006 | 08:00 PM
Default Re: (Jedi_Sol)
Thanks sorry didnt see that
Old May 8, 2006 | 09:43 PM
axtran's Avatar
white smoke is usually something like coolant leaking into chamber and combusting, good luck, you can still pass smog sometimes if the smog guy is nice and your pretest is successful
Old May 9, 2006 | 07:21 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragracer1492 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks sorry didnt see that </TD></TR></TABLE>
Don't bother calling, just go in there and be honest about your situation. They are not stingy with extensions.
Old May 9, 2006 | 07:30 AM
boosted civic 2k6's Avatar
i get white smoke up in the high end too but i passed alright. the guy doesnt rev the motor pass 3k here in renton, WA. if theres coolant in it then i really have no idea how that happens if your head isn't warped or no crack in the black since you just got a new head gasket.
One thing i was thinking off if you want to cheat the system, is to run water instead of coolant or mix 80/20 or 90/10 water vs coolant. IF you are indeedly getting coolant into your cylinders. but dont do that for long because water boils and freezes in engines without engine coolant mix. i dont endorse this experiment, i prefer to do things the right way but if you want theres an idea.
One thing i know to help you pass, is to run the car for atleast 30 minutes before the test so it warms up your cat and everything is tippy toppy.
wonder if water condensation shows up on the emissiosn test?
Old May 9, 2006 | 03:05 PM
OxidizedSol's Avatar
Extensions are given out with proof that your failed smog. Have you tried changing the catalytic converter? That usually helps a lot.
If you're strapped on cash, CA does offer repair assistance to those who qualify. For more information, visit: http://www.smogcheck.ca.gov/st...6.htm
Hope that helps!
BTW, what is a b18b7? Do you mean b18b1?
Modified by OxidizedSol at 4:31 PM 5/9/2006
Old May 9, 2006 | 08:50 PM
Default Re: need to pass smog (OxidizedSol)
damnit sorry i meant to put d15b7, for some reason i keep thinkin the engine i have is a b18b prolly cause i want one so bad, hahaha
Old May 9, 2006 | 11:34 PM
broketuner-Sol_Si's Avatar
If its only smoking in the high rpms you should be fine, when I went to get smogged/BARd they didn't take it much past 4000RPMs. But I would check your cat and run some fuel system cleaner and some of the guranteed to pass stuff, even though it means another oil change(It helps a lot).
Old May 10, 2006 | 07:39 AM
TEST ONLY's Avatar
Dude, a tailpipe smoking ride that needs to pass smog, you are in a tough predicament. Hmmmm..... what you're going to have to do is go get another DMV extention until you rack up enough dough to fix your little issue. Go to the DMV, show them that your ride didn't pass smog, tell the DMV clerk that you need at least another month. Good luck!
romoracing
Southern California
Jul 10, 2014 09:11 AM
bbcnet
Jul 9, 2004 02:32 AM
