0bd0to0bd1 problems !
Old May 8, 2006 | 02:09 PM
hedtrip's Avatar
Default 0bd0to0bd1 problems !
ok im doing a 0bd0 to 0bd1 conversion on a crx hf with a y8 in it .
im using a 92-95 civic dx ecu . it starts & runs ,. but when it gets 2 about 4 k it's like it looses power then it just shoots back up to 5 k . what would causse this? is it the ecu ? or my 02 sensor or dizzy ?
Old May 8, 2006 | 02:20 PM
_Keith_'s Avatar
Any codes?
Old May 8, 2006 | 02:44 PM
hedtrip's Avatar
Default Re: (_Keith_)
i think 4 .. im new to obd1
Old May 8, 2006 | 03:39 PM
hedtrip's Avatar
Default Re: (hedtrip)
no sorry i was wrong .. it's throwing 41 . heated 02 sensor
Modified by hedtrip at 6:10 PM 5/8/2006
Old May 9, 2006 | 04:58 PM
hedtrip's Avatar
ok i changed the 02 sensor & it's driving better . but still lacking power
but im hoping thats just thee dx ecu .
does it mean anything when u go 2 check the codes & the the check engine light comes on but oesnt blink ?
Old May 9, 2006 | 05:34 PM
crxnj's Avatar
its probably a combination of the dx ecu and the low cam mode of the engine making it feel slow..my advice to you is hook up vtec and chip the ecu,,or possibly find a p28 if you dont want to chip..
also im not sure about obd1 but dont you have to reset the ecu after you fix the code..??? unhook the negative battery cable for like a minute then hook it back on and start the car and just let it idle..
Old May 9, 2006 | 06:30 PM
PyroProblem's Avatar
Default Re: (Mr.speaker)
Its normal if you have no codes/faults present for the light to stay on when you jump it...This is also how you set your base ignition timing...
Your CEL will be off if you have no codes. If it stays on when you jump it, you have no codes...
HTH...
Is the base timing set? That will make it feel slow too...
XX3LXERAKOXX
Jul 8, 2017 08:20 AM
twilusz
Jul 2, 2017 08:58 AM
blackwidow_prin
Aug 18, 2011 05:24 PM
crxmadness
Sep 21, 2006 12:43 PM
whitesohcs
Jun 30, 2004 03:03 PM
