problem with stuttering noises form exauhst
Old May 8, 2006 | 01:40 PM
immrtaltchnq's Avatar
Default problem with stuttering noises form exauhst
ok so im havin problems with my car and its annoying me so i decided id come on here and ask
ok so my car is idleing low like on the verge of shutting of and when i take off the exauhst makes a stuttering noise as i press down on the gas
this is causing my acceleration to be slow and it soemtimes stops when im goin fast enough in certain gears
anyone know what it could possibly be?
Old May 8, 2006 | 02:33 PM
keemosaki's Avatar
Default Re: problem with stuttering noises form exauhst (immrtaltchnq)
so something is rattling under your car? common rattle is heat shield on cat. try taking a look under your car when it is not hot and check the looseness of that shield.
Old May 8, 2006 | 02:38 PM
Default Re: problem with stuttering noises form exauhst (keemosaki)
no ntohigns rattleing the exauhst noise is jsut a studer
and it makes me not be able to barely accelrate
Old May 8, 2006 | 02:47 PM
t0p_sh0tta's Avatar
Misfire maybe?
When's the last time you changed your plugs/rotor/wires? Is the valve cover gasket leaking into the spark plug tubes?
Old May 9, 2006 | 06:25 PM
Default Re: problem with stuttering noises form exauhst (t0p_sh0tta)
i havent changed ems ince ig ot the car and i dunno what the guiy before me did
im gonna cehck out those things tomorrow
but my cars starting to die out on me taking off from first
and its smokes like no other.. like no matter what
leroyb
15
Aug 8, 2006 06:23 AM
b0wti
May 24, 2005 03:12 PM
just4747
Sep 18, 2004 08:23 PM
AlphaQup
May 4, 2003 07:10 AM
E Swift
Sep 10, 2001 11:05 AM
