fuel pressure drops after priming
si rail, stock injectors, stock fpr (ive also tried a b&m reglator)....when i pime the fuel system it shoots up to 40psi like it should, then begins to fall, pauses at 20 and then seems to settle at 10 psi within 30 seconds. this is after i found a leak from the #4 injector bc of a damaged 0 ring. there are no leaks to be found anywhere, car does start up and run. anyone have any ideas??
edit.....just let it run for awhile and then the p[ressure stopped dropping as fats...then went and filled the gas tank and now the pressure only drops slightly from 40 to about 36-38 psi
Modified by bleedblue94 at 5:30 PM 5/8/2006
si90rex
15
May 18, 2010 05:03 PM
Fuel pressure DROPS to Zero immediatly after Priming (aftermarket sysytem) ALREADY CHECKED FOR LEAKS
skunkwhat
Aug 19, 2004 04:55 PM
