Socket size for the oil pressure sender?
Old May 8, 2006 | 11:23 AM
NoVALude's Avatar
Default Socket size for the oil pressure sender?
Forgot to torque the oil pressure sender unit (?) on the block, under the oil filter....I have a 21 mm socket and it is too small. Next size up I had on hand was 30...
Anyone happen to know (or can measure one) the socket size so I can torque it down.
Old May 8, 2006 | 11:24 AM
The Weather Man's Avatar
I don't know guy, but are you boosting the h22 or something?
I would recommend you looking into a sandwich plate. Its much more safe - in regards to breaking something important. can't really go wrong with a sandwich plate.
Old May 8, 2006 | 11:28 AM
NoVALude's Avatar
Default Re: (The Weather Man)
No boost....all N/A.
sandwich plate?
Old May 8, 2006 | 12:14 PM
A Blue Lude's Avatar
Default Re: Socket size for the oil pressure sender? (NoVALude)
My 97+ Helms says that it's 1/8 in. British Standard Pipe Taper.
I have no idea what that means.
Old May 8, 2006 | 04:42 PM
yOnKiNaToR's Avatar
Default Re: Socket size for the oil pressure sender? (A Blue Lude)
it's 24mm.
most aftermarket ones are 22mm
Old May 8, 2006 | 05:26 PM
NoVALude's Avatar
Default Re: Socket size for the oil pressure sender? (yOnKiNaToR)
Thanks!
Old May 9, 2006 | 05:34 AM
NoVALude's Avatar
One more quick question.....
When the sender was removed before the block went to the shop I had it sitting around and noticed that there appeared to be some teflon tape left on it. I re-wrapped it with teflon tape.....that right?
Old May 9, 2006 | 05:51 AM
Lewdin' Incognito's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NoVALude &raquo;</TD></TR><TR><TD CLASS="quote"> I re-wrapped it with teflon tape.....that right?</TD></TR></TABLE>
You are correct, sir!
I wrapped the bejesus out of mine....just as long as you kept the tape out of the port.
Old May 9, 2006 | 06:12 AM
NoVALude's Avatar
Default Re: Socket size for the oil pressure sender? (Lewdin' Incognito)
Wrapped mine pretty good, and the port is on the bottom of the unit, right?
did not see any hole other then on the bottom.
Modified by NoVALude at 7:43 AM 5/9/2006
RedPinoySi
Jun 12, 2007 05:23 PM
ITR3189
Jul 27, 2005 11:02 AM
g2_boosted
Oct 13, 2004 10:52 PM
acurafighter
May 25, 2004 09:13 AM
MeanGreenEG9
Jan 13, 2003 02:00 PM
