Identify this sensor
Old May 8, 2006 | 08:35 AM
OrangeBoost's Avatar
Default Identify this sensor
So I was plugging everything back in after my swap and Im left with one sensor that I dont recognize. Im at work right now, so no pics but I will try and describe it.
The sensor has one hole for a bolt/screw and a small cylinder on top. It has three nipples for lines and one line is coming from the charcoal canister. Where does this go and what do the other two inlets/outlets go to?
Old May 8, 2006 | 08:56 AM
dema12co's Avatar
Default Re: Identify this sensor (OrangeBoost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OrangeBoost &raquo;</TD></TR><TR><TD CLASS="quote">So I was plugging everything back in after my swap and Im left with one sensor that I dont recognize. Im at work right now, so no pics but I will try and describe it.
The sensor has one hole for a bolt/screw and a small cylinder on top. It has three nipples for lines and one line is coming from the charcoal canister. Where does this go and what do the other two inlets/outlets go to?</TD></TR></TABLE>
ITS A COW...NO NO WAIT.....A GOAT?
Old May 8, 2006 | 10:01 AM
LowSlow93Sol's Avatar
You sir, have found the Evap. Purge Solenoid. It is used to control emissions on the USDM Hondas, but not in Japan.
Notice on your old engine there is a vacuum line on the rear of the Intake Manifold. The Jdm Version doesnt have this fitting on the Manifold. Doesn't do any harm to plug the line. I have done this with a SOHC ZC and it has run perfect... but if your in a smog state you may want to swap manifolds or hide that thing VERY well.
P.S. what motor are you running?
Old May 8, 2006 | 01:39 PM
Default Re: Identify this sensor (onefast93sol)
Sorry, Im running a D16Z6 (so it should all be there). Yes there is a nipple on the back. So the bottom inlet goes to that nipple and the other open one goes where?
Old May 9, 2006 | 10:32 AM
Ill get Pics of mine up tonight so you know how to rout it.
Old May 9, 2006 | 07:33 PM
Ok here is mine with the correctly labled vac. lines the third connector is actually an electrical plug. btw mine is zip tied b/c i havent had the time to drill and tap the new manifold. I hope this helps!
Old May 9, 2006 | 07:56 PM
dem0nk1d's Avatar
Blowoff Valve... lol! j/k
Old May 9, 2006 | 08:01 PM
Default Re: (dem0nk1d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d &raquo;</TD></TR><TR><TD CLASS="quote">Blowoff Valve... lol! j/k
</TD></TR></TABLE> LMAO....my car was Boosted and i didnt even know it!!
Old May 10, 2006 | 06:58 AM
ezza's Avatar
Default Re: (onefast93sol)
i broke the cylinder part off mine during the swap
mar7pau
Aug 29, 2010 10:34 AM
EF-8SiR
Feb 23, 2009 07:27 PM
mortificationrock
Jul 28, 2008 04:46 PM
yellowwinter
Feb 13, 2005 11:21 PM
musclefella
Apr 15, 2004 09:12 AM
