IACV sucking at operating temperature?
Old May 8, 2006 | 07:11 AM
elpiar's Avatar
Default IACV sucking at operating temperature?
If you run your car at operating temperature (radiator fans turn on, thermostat opens), the idle should be like 700-800 right?
Now if I plug the IACV inlet at the throttle body, it's still sucking. If I unplug the IACV connector, it's also still sucking. My idle with the IACV connected is 1.5k, and with the connector out it's still 1k.
The only way I can get it to idle low is by plugging the inlet with my finger. Does this means my IACV needs replacement? (Already take it off and cleaned it, makes no difference)
Old May 8, 2006 | 07:15 AM
DC2 Mang's Avatar
Default Re: IACV sucking at operating temperature? (elpiar)
adjust the screw on the throttle body
let the car get harm, unplug the IACV and adjust the screw, turn the car off then re-set your ecu and you should be good
Old May 8, 2006 | 07:26 AM
elpiar's Avatar
Default Re: IACV sucking at operating temperature? (JDMdc2lsVtec)
I tried adjusting the screw but it will not change. And I am guessing it's because the IACV is till open even after I unplug the wires. Does yours still sucking even if you unplug the connector?
Old May 8, 2006 | 07:50 AM
DC2 Mang's Avatar
im not sure, maybe you have a damaged one, they break all the time, i would try using a friends to see it it is broken or buying another one
Old May 8, 2006 | 08:11 AM
elpiar's Avatar
Does a B16, Type R, or D series IACV fit in my GSR??
Old May 8, 2006 | 08:24 AM
DC2 Mang's Avatar
the b16 and ITR should fit just fine
Old May 8, 2006 | 12:35 PM
SavEM1's Avatar
before you replace it, try cleaning it out with carb cleaner. Spray in the screen and inside it. Tap out all the black stuff out. It should help
Old May 8, 2006 | 12:40 PM
elpiar's Avatar
Default Re: (Hcivic02)
I already did, but still having the same problem. Thanks for the suggestion though.
Old May 8, 2006 | 12:45 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (elpiar)
Have you tried spraying it with carb cleaner through the inlet in the throttle body while the car is running?
Old May 8, 2006 | 02:30 PM
elpiar's Avatar
Default Re: (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Have you tried spraying it with carb cleaner through the inlet in the throttle body while the car is running?</TD></TR></TABLE>
Yes I did both while the car is running and then taking it off and cleaning it off the car. same problem
thewrai6th
Oct 28, 2018 05:32 PM
mateku
Nov 24, 2015 03:26 AM
BDogggUT34
Jan 18, 2005 04:05 PM
civic-lsi-vtec
16
Dec 24, 2004 05:26 AM
cj7420
Mar 24, 2002 06:55 AM
