intake manifold
please search.
http://www.accordinglydone.com...11176
https://honda-tech.com/zerothread?id=1521476
https://honda-tech.com/zerothread?id=1458671
Those are just a couple I found off a quick search. There are more, just run a search in the archives in the Accord forum for "intake manifold".
But to answer you question, yes, it will work with some modifications.
i did search i dont know whats wrong with my computer but this has happened more than once,
"» No Results Found
Your search for intake manifold returned no results.
Please try different search criteria or a different data set."
i tried searching after my post and it still turned up nothing.
sorry but thanks though
"» No Results Found
hmm... wierd. Are you searching in the recent or archives?
I tried the recent threads and got the same result of...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda-Tech Search »</TD></TR><TR><TD CLASS="quote">» No Results Found
» Go Back</TD></TR></TABLE>
But when I did a search in the archives for the same criteria I got...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda-Tech Search »</TD></TR><TR><TD CLASS="quote">» Search Results
Your search for intake manifold returned 16 results.
» New Search</TD></TR></TABLE>
and the list of the results.
Maybe you just tried the recent and forgot about archives?
IDK, either way. If you'd like to see the other results, just type in "intake manifold", select the Accord Forum and select "Archived Content" then click "Next". You should get the same 16 results I did.
On a side note though, the thread on AD has some good info in it and it's sorta ongoing. A few people are doing the swap and have posted questions and concerns about certain areas.
Prudz_lude
Oct 11, 2007 09:42 PM
