Choosing cam
Old May 7, 2006 | 11:55 PM
HNRevHard's Avatar
Default Choosing cam
got question for na guy ,since i change my setup from turbo to N/A .
I need to choose the Cam for my setup.
LS/VTEC setup
Je piston and rod, 12.1 comp
Jg pro series Gsr head.
Dual valve springs
Titanium retainer
Oversize valve
Port and polish
Port match intake manifold
Str Cam gears
65mm throttle body
Light weight flywheels
act clutch
510c Injector
4-1 2.5 collector header with custom 2.5 inch cat-back
so what kinda cam should i be buying
FS: Je 81mm low comp piston OBO
JG Turbo cam OBO
Old May 8, 2006 | 12:05 AM
UncleD's Avatar
Default Re: Choosing cam (HNRevHard)
Your injectors are gonna be a little large, but the RM M22xx would make a ton of power in that motor....a ton.
Old May 8, 2006 | 07:26 AM
DC2 Mang's Avatar
Default Re: Choosing cam (clean rice)
the rocket m22 or skunk2 stage 2 IMO
Old May 8, 2006 | 08:33 AM
RaceCarRyne's Avatar
Default Re: Choosing cam (JDMdc2lsVtec)
june 3
Old May 8, 2006 | 08:41 AM
jaydem_ekizzle's Avatar
skunk2 PRO 2's, def get a good tune with injectors that big and maybe upgrade the tb to 70 and get a nice IM?
Old May 8, 2006 | 09:11 AM
UncleD's Avatar
Default Re: (jaydem_ekizzle)
Pro 2's are gonna be a bit large, if you did the Pro series I would do the 1. All of these cams are good recommendations really, you can never go wrong with a Jun 3, a S2S2 will make power and so will the Pro1. I would seriously put the M22xx up against any of those for your motor though
Old May 8, 2006 | 09:30 AM
HNRevHard's Avatar
I'm not a N/A person, so just wonderring who made M2xx cams? and how a Crane Stage 2 cam? does it any good?
Old May 8, 2006 | 09:37 AM
HNRevHard's Avatar
by the way what kinda power do i'm looking at which that setup ?
Old May 8, 2006 | 09:39 AM
UncleD's Avatar
Default Re: (HNRevHard)
The M series are made by Rocket Motorsports. As far as the Crane's, I have never seen anyone make any good power with them...but I'm sure it's possible. Here are a few dyno's with the RM M22's...
This is a <U>non-tuned</U> motor, usually with the M22's you will see them peak around the 9-9,200 mark in a well breathing motor.
Link to that dyno: https://honda-tech.com/zerothread?id=1518936
Stock ITR with a good header and M22's tuned.
https://honda-tech.com/zerothread?id=1603212
M22's vs. Pro1's tuned by Jeff Evans. Dotted line are the 22's. (not sure why the power dropped off so soon...this is a very old graph.)
https://honda-tech.com/zerothread?id=1141681
Old May 8, 2006 | 12:25 PM
what are the m24? bigger then the 22 im assuming what would they compare with?
Old May 8, 2006 | 07:23 PM
UncleD's Avatar
Yes the M24's are a hotter version of the M22. I would put the M24 comparable somewhere in the middle of a S2 Pro1 and a S2 Pro2.
Old May 8, 2006 | 07:39 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: (clean rice)
I agree with clean rice on the JUN3's but anything bigger and you are asking for valve to valve clearance problems because I believe you said you had oversized valves ....how much over??? 1/2mm or 1mm ??
Old May 8, 2006 | 09:28 PM
HNRevHard's Avatar
i have to call JG and and ask how much it over. but i would think i 1mm over
micktype r
10
Mar 24, 2009 10:07 AM
Spracer03
Jun 15, 2008 08:13 AM
GSRCRXsi
15
Sep 27, 2006 01:23 PM
cjohnson_2
Nov 25, 2003 06:13 PM
