LSVTEC temp gauge problem??
Old May 7, 2006 | 08:35 PM
All Motor Ek99's Avatar
Default LSVTEC temp gauge problem??
i dont realli drive the car much its just to race so its not daily driven... aite so i just got a brand new lsvtec build in my crx... i got it from the shop but the temp gauge doesnt work.... motor was driving fine until today it was kinda hot today and i get home and the resourvir tank was bubbling wen i reved the motor..... my car eats up coolant like crazy since i got the car last week car is dyno tuned and everything.... so is this the thermostat thats not working and causing the coolant to shoot towards the resouvir tank wat u guys think is the problem?? i wanna get this fixed tomorrow cuz i dont wanna overheat my car
Old May 7, 2006 | 09:44 PM
Default Re: LSVTEC temp gauge problem?? (NA-Ef8 (626 Moderator))
anyone?
Old May 7, 2006 | 11:14 PM
Honda-bond's Avatar
Sounds Like you have a blown head gasket. Be careful, you could be steadily destroying your motor. Is it sleeved?
Old May 8, 2006 | 08:55 AM
yea darton sleeves
Old May 9, 2006 | 02:42 AM
Honda-bond's Avatar
Default Re: (NA-Ef8 (626 Moderator))
Check to see if the sleeves fell. Also, maybe the head is warped, or maybe the block surface is warped.
I've had sleeves fall once, but only once. I’ve also had to resurface a block 10 thou just to get it flat, and I've had similar problems with heads that have been overheated.
Old May 9, 2006 | 08:27 AM
Default Re: (Honda-bond)
problem was fixed radiator was clogged thanks for the replies
DTHADDR
11
Feb 5, 2013 12:28 AM
bobjohnson
10
Oct 31, 2007 09:38 PM
Da1spaz247
Oct 12, 2005 02:33 PM
CRXracer88
Jan 25, 2004 11:18 AM
BlackGSR
Oct 15, 2002 11:33 PM
