cam or clutch
Old May 7, 2006 | 08:07 PM
speedysohc's Avatar
Default cam or clutch
i have a del sol si w/ i/h/e
do i go w/ a new clutch or put a cam w/ camgear and timing belt on it
also what kind of cam would i look @
help me out guys thnx
Old May 7, 2006 | 08:09 PM
Sketch_hs's Avatar
Default Re: cam or clutch (speedysohc)
swap or turbo
Old May 7, 2006 | 08:11 PM
BauleyCivic's Avatar
Risky Business
Default Re: cam or clutch (Sketch_hs)
Well, a clutch is kind of an essential item dude. Do you need a new clutch? If you do, then get the clutch. If you don't need a clutch, don't waste any more money bolting **** on to that d-series. Save up for a turbo kit.
Old May 7, 2006 | 10:00 PM
sohcvtec1995's Avatar
Default Re: cam or clutch (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">Well, a clutch is kind of an essential item dude. Do you need a new clutch? If you do, then get the clutch. If you don't need a clutch, don't waste any more money bolting **** on to that d-series. Save up for a turbo kit.</TD></TR></TABLE>
exactly. you will spend more money and time on doing a cam and gear for not that big of a gain unless you do the whole head. As oppose to getting a clutch that you are going to need anyways if you start makeing some actual power.
Old May 7, 2006 | 10:25 PM
papito_85's Avatar
Boost it!
Old May 8, 2006 | 07:08 PM
speedysohc's Avatar
well clutch it is then, any idea what direction i should go with that? should i save for the flywheel and get it all in one shot or no need?
thnx for posts
TypeSFTW
16
Mar 13, 2008 05:50 PM
2006Si
16
Dec 29, 2005 08:27 AM
DANgerous
Apr 4, 2004 01:37 PM
killerslp
Sep 16, 2003 12:38 PM
