cam or clutch
cam or clutch
i have a del sol si w/ i/h/e
do i go w/ a new clutch or put a cam w/ camgear and timing belt on it
also what kind of cam would i look @
help me out guys thnx
Risky Business
Re: cam or clutch (Sketch_hs)
Well, a clutch is kind of an essential item dude. Do you need a new clutch? If you do, then get the clutch. If you don't need a clutch, don't waste any more money bolting **** on to that d-series. Save up for a turbo kit.
Re: cam or clutch (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">Well, a clutch is kind of an essential item dude. Do you need a new clutch? If you do, then get the clutch. If you don't need a clutch, don't waste any more money bolting **** on to that d-series. Save up for a turbo kit.</TD></TR></TABLE>
exactly. you will spend more money and time on doing a cam and gear for not that big of a gain unless you do the whole head. As oppose to getting a clutch that you are going to need anyways if you start makeing some actual power.
2006Si
16
12-29-2005 08:27 AM
