h22 eg questions
Old May 7, 2006 | 07:40 PM
beaneg6's Avatar
Default h22 eg questions
i have a 94 jdm h22a 100% stock internals, i am going to be adding a fully port and polished JG pro series head with JG valve springs and retainers. it has 0.5mm oversized intake valves and the exhaust valves are stock diameter on a stock bottom end, with a rmf header. I have 2 questions: 1. what cams?(keep in mind this is a daily driver) 2. what type of tunning should i use, im thinking hondata but im not too sure, what kind of whp should i expect?
Old May 7, 2006 | 10:00 PM
beaneg6's Avatar
Default Re: h22 eg questions (beaneg6)
anyone?
Old May 8, 2006 | 07:07 AM
beaneg6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaneg6 &raquo;</TD></TR><TR><TD CLASS="quote">anyone?</TD></TR></TABLE>
Old May 8, 2006 | 08:35 AM
RaceCarRyne's Avatar
type-s cams.. cant go wrong.. makes good power..
Old May 8, 2006 | 09:59 AM
ej1_lsvtec's Avatar
sup bean hey just ask randy he should be able to tell you
Old May 8, 2006 | 12:52 PM
SP GARAGE's Avatar
daily driven type-S cams would be fine. if you go bigger go skunk2 stage 1
Old May 8, 2006 | 07:26 PM
beaneg6's Avatar
Default Re: (mixxxwell)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mixxxwell &raquo;</TD></TR><TR><TD CLASS="quote">daily driven type-S cams would be fine. if you go bigger go skunk2 stage 1</TD></TR></TABLE>
you still have them type s cams?
Old May 9, 2006 | 06:26 PM
22boost's Avatar
Default Re: (beaneg6)
from what i have been told type s cams are pretty much the best cam for the h22. i have talked to randy in person many times. he would be the one to ask, i know he has tried almost every cam there is for the h22. you can pm him at 'missing gears'
Old May 9, 2006 | 06:33 PM
AllMotorRandy's Avatar
Default Re: (93dxkid)
for daily driving i would defintaly say type-s....... makes good enough power for the street.
Old May 9, 2006 | 06:37 PM
beaneg6's Avatar
Default Re: (AllMotorRandy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorRandy &raquo;</TD></TR><TR><TD CLASS="quote">for daily driving i would defintaly say type-s....... makes good enough power for the street. </TD></TR></TABLE>
yeah for sure man, im not flaking out on you just waiting on that tax check, then your head will be mine,
ekblacknight
12
Feb 28, 2008 12:16 PM
jakfrost84
Feb 6, 2008 07:32 PM
Suzuka_Lude
Jan 1, 2007 10:01 AM
es_squared
Nov 25, 2004 02:35 PM
95accordh22a
Nov 6, 2004 07:25 AM
