LS water pump & oil pump in gsr?
Old May 7, 2006 | 07:39 PM
mymeatb18
Default LS water pump & oil pump in gsr?
would my ls water pump and oil pump work in my gsr
Old May 7, 2006 | 08:22 PM
mymeatb18
Default Re: LS water pump & oil pump in gsr? (mymeatb18")
bump
Old May 8, 2006 | 07:55 AM
mymeatb18
bump to da top
Old May 8, 2006 | 08:09 AM
Fixxe2's Avatar
would.. yes...
both fit yes..
but, the coggwheel? on the waterpump is smaler, so you need a LS belt...
also the waterpump will spin a bit to fast on the high revs... if i were you, i would nog use the ls waterpump.
the oilpump is the same as the GSR yes.
Old May 8, 2006 | 08:30 AM
RaceCarRyne's Avatar
Default Re: LS water pump & oil pump in gsr? (Fixxe2)
no... oil pumps are only the same in obd2 not obd 1..
Old May 8, 2006 | 10:32 AM
mymeatb18
Default Re: LS water pump & oil pump in gsr? (DC2jdmIntegra)
well the oil pump would be coming from a obd0 ls and would it really matter what obd it is
Old May 8, 2006 | 10:58 AM
Fixxe2's Avatar
is that due to the crank sensor crap??
Old May 8, 2006 | 01:54 PM
mymeatb18
Default Re: (Fixxe2)
well if it has to do with the crank position sensor then wut if i use a obd0 sensor which im gonna use anyways guys im building a gsr block and right now its completly bare except for crank, rods, and pistons. so i was planning on using all my parts neccesary to complete it from my obd0 b16 block that came out of my car when i was in an accident so this brings me back to question would i be able to use these pumps or not?
Modified by mymeatb18" at 7:31 PM 5/8/2006
Old May 8, 2006 | 04:31 PM
NJIN BUILDR's Avatar
Default Re: (mymeatb18")
First you say LS pumps and then you say B16.The B16 is the same as the gsr.
Old May 8, 2006 | 04:43 PM
mymeatb18
Default Re: (NJIN BUILDR)
cuz i have both sets but my water pump in my b16 block is broken but the ls pumps in my ls are brand new thats why i want to use the ls but u say it doesnt work so does anybody know exactly why the pumps wont work is cuz of a sensor, teeth, doesnt fit. really wut is it?
Old May 8, 2006 | 08:54 PM
mymeatb18
bump my last post
Old May 9, 2006 | 01:26 PM
mymeatb18
bump
Old May 9, 2006 | 01:40 PM
97L-esVeeTeg's Avatar
The LS waterpump will fit, and will work if you use the ls timing belt, the only thing you have to watch out for is high rpm operation, the smaller ls pump will spin faster, which can cause cavitation, a vtec pump is a better idea. As far as the oil pump goes, get an obd2 pump.
Old May 9, 2006 | 02:10 PM
mymeatb18
Default Re: (97L-esVeeTeg)
but is there any way to convert the waterpump so it doesnt get fucked up like using the wheels from the vtec pump and i want to know what is the reason why the oil pump has to be a certain obd but i found out today my obd0 oil pump is fine so that will work right
thanks
Old May 9, 2006 | 06:28 PM
The gears are pressed on the water pumps and are not changable.The odd0 and obd2 oil pumps use a different lower timing belt cover.You can buy a new water pump for around $60.
Old May 9, 2006 | 07:05 PM
mymeatb18
alright so i got to buy a new waterpump so for the oil pump i just use the obd0 lower timing belt cover with the obd0 oil pump
Old May 10, 2006 | 01:31 PM
mymeatb18
bump
Old May 11, 2006 | 08:49 AM
mymeatb18
bump the ******* question
Old May 11, 2006 | 06:17 PM
mymeatb18
bump again need an answer. could i use an obd0 b16 oil pump on obd1 bare GSR block (nothing but the crank) using the obd0 timing belt cover?
young geezer
Oct 1, 2011 12:21 PM
deemy72
Jul 9, 2009 10:20 AM
1995sir
Jul 10, 2006 10:19 PM
User 42624
Nov 1, 2005 10:35 PM
kasso
Jan 28, 2005 05:06 AM
