Starting Problem
Old May 7, 2006 | 07:24 PM
Hybrid14's Avatar
Default Starting Problem
i have a 91 si hatch with a built ls/vtec swap. recently when i try to turn it on it will not start. starter turns, i have spark, but no fuel pressure. i can hear the fuel pump prime (btw replaced main relay) but no pressure builds up. then after much heart ache and gnashing of teeth, it will just start up like every things fine. my theory is that maybe some junk is clogged in there? what do ya'll think? i replaced fuel filter about 1000 miles ago (before the problem) fuel injectors have been cleaned. i don't know but i got to figure this out, I'll be in a parking lot for an hour trying to get it to start!
Old May 7, 2006 | 07:27 PM
EF_ST@TUS's Avatar
make sure plugs and wires are good!! Me and my buddy just had same problem.
Old May 7, 2006 | 08:37 PM
rayzian's Avatar
Default Re: (Lost_in_a_world_so_cold)
I have the same problem. Very embarresing, especially at a gas station after you just filled up and you sit there for a good minute or two cranking and cranking until it finally starts.
Old May 8, 2006 | 10:37 AM
Hybrid14's Avatar
yeah it is embarresing! i replaced plugs about a week ago and wires are good. any one know how to fix the problem? fuel pressure sits on 0 then eventually it builds to 40 and it starts. i don't think it is the pump, because it works after it starts and i know that it is priming. is there a filter in the pump that could be clogged? if so do need to replace it or just clean it?
Old May 8, 2006 | 08:34 PM
dc5_integra's Avatar
Default Re: Starting Problem (Hybrid14)
Theres not a filter in the pump but there is a fuel filter. It may be clogged but I doubt thats a problem. It could be a fuel pressure regulator because that regulates how much fuel is getting pumped.
Old May 8, 2006 | 09:58 PM
90JDMEF8's Avatar
i would take the fuel line off from the fuel rail or at least loosten it next time it wont start... if you are getting fuel to there then that narows it down to injectors. if it isnt to there then its A) A Clogged Fuel Line B) Fuel Filter C) Pinched Fuel Line D) Any # Of The Above
Old May 8, 2006 | 10:03 PM
onepoint6i's Avatar
Default Re: (Hybrid14)
this happens everyday? its goes to 0 everytime you shut the engine off?
Old May 9, 2006 | 03:06 PM
Hybrid14's Avatar
no it doesn't happen everyday. it will go a day or 2 and be fine and then it will do it 2 or three times in a row. no rhyme or reason. it will hold fuel pressure for a while after i cut it off and then die down, but thats normal. i have just noticed that when this happens it is though i haven't primed the pump. thats why i think it is a clog.
thanks for the suggestions guys, i am going to have to wait for it to happen again to narrow it down, but i'll keep you updated.
jayroddrumz
10
Jun 11, 2009 12:01 PM
JsSIR
Apr 28, 2009 05:25 AM
J-SpecRacing
Mar 9, 2008 03:58 PM
Tony R
Jun 15, 2004 07:09 AM
Magick211
10
May 1, 2004 09:44 PM
