Icebox and K&N filter question
Old Apr 10, 2002 | 11:39 AM
98TypeR896's Avatar
Default Icebox and K&N filter question
I understand Comptech wants to sell their air filter with the Icebox but has anyone tested a, or know which, K&N filter that will fit the Icebox?
What are the size dimensions of the Comptech air filter? Is it tapered? This way I, we, can match the size with a K&N unit.
Thank you in advance for help.
Old Apr 10, 2002 | 11:41 AM
MPH's Avatar
MPH
New User
Default Re: Icebox and K&N filter question (98TypeR896)
I used a modified K&N RU 2820. I now have the comptech filter and will dyno test both of them within a week.
Old Apr 10, 2002 | 11:52 AM
R-Type's Avatar
Default Re: Icebox and K&N filter question (MPH)
Does the K&N E-2427 fit in the Icebox as well?
Old Apr 10, 2002 | 11:57 AM
IntegraT's Avatar
What would be the point of this?...is it cost?
Old Apr 10, 2002 | 12:01 PM
MPH's Avatar
MPH
New User
I'll tell you that the K&N sounds alot better the the foam.
Old Apr 10, 2002 | 12:14 PM
98TypeR896's Avatar
Default Re: Icebox and K&N filter question (IntegraT)
Not a cost thing at all. First, I would just rather buy a K&N filter over the Comptech. Second, Comptech admits, at least they used to, the K&N flows the same when freshly cleaned and oiled but better after usage. It is just a preference thing and my curiosity.
Old Apr 10, 2002 | 01:53 PM
Rob Dizzle's Avatar
so....
which K&N filters will work with the icebox?
Old Apr 10, 2002 | 02:54 PM
ITR764's Avatar
Default Re: Icebox and K&N filter question (bob46802)
so....
what about the stock box??? it's the 2427 filter right? POS search isn't working worth a fock!!
Old Apr 24, 2002 | 12:28 PM
Integ Grl's Avatar
Default Re: Icebox and K&N filter question (ITR764)
Just reviving this topic since the Q's haven't been answered...
Does the E-2427 K&N filter fit in the Icebox? How about the stock airbox? TIA.
Old Apr 24, 2002 | 12:32 PM
slackeR1366's Avatar
Default Re: Icebox and K&N filter question (Integ Grl)
The 2427 does fit the stock box, I run my R with it.
not to sure about the icebox though.
Old Apr 24, 2002 | 12:34 PM
MPH's Avatar
MPH
New User
Default Re: Icebox and K&N filter question (PHyT-R)
If your run the 2427 in the stock airbox than the same filter should fit the icebox, because the comptech filter fits the stock airbox and the icebox.
Old Apr 24, 2002 | 12:49 PM
98TypeR896's Avatar
Well, the Ice Box arrived today for me to find a fitting K&N unit. I'll start by testing the stock direct replacement, K&N# E-2427, then go from there. Now all i have to do is find a local shop that has that in stock, as well as others if it fails the fitment test. any suggestions for the northern va area? anyone!?
Old Apr 24, 2002 | 12:57 PM
MPH's Avatar
MPH
New User
They will probably have to order it. I'll sell you the comptech filter for $40.00 with oil and cleaner. I'm in MD.
Old Apr 24, 2002 | 02:09 PM
98TypeR896's Avatar
If you have some K&N's, especially the E-2427, i'll stop by this weekend to test fit them. My goal is to find the definative answer on which K&N(s) will fit the Ice Box for everyone, and myself. I appreciate the offer.
Old Apr 24, 2002 | 03:29 PM
fso_BamBam's Avatar
New User
Yep, here's my post that answers most questions:
https://honda-tech.com/zerothread?id=143177
The pics don't seem to work, so here they are again:
1. The K&N Unit:
2. One angle:
3. Another:
I'd highly recommend that you get this filter (E-2427)
http://www.martelbros.com
[Modified by fso_BamBam, 12:30 AM 4/25/2002]
Old Apr 24, 2002 | 04:03 PM
Eric R's Avatar
Default Re: Icebox and K&N filter question (fso_BamBam)
How does that K&N filter seal the back of the stock box if it doesn't have the lip to install the rubber sealer?
I have used the Comptech filter in the tricked stock box for a while and in my opinion this filter works. You can feel the added power. Also, I think it flows better than the K&N. The Comptech filter is open at the front and has that tapered horn shaped inlet inside. The K&N is closed and I don't know if it has the same feature inside. If it is straight like the stock one, I don't think it would be that efficient. Just MHO.
Old Apr 24, 2002 | 04:06 PM
Toda Party's Avatar
Default Re: Icebox and K&N filter question ('01ITR#950)
the e-2427 seals...
i had a pic but i lost it when my comp died on me
basically its molded plastic that fills the gap at the back of the airbox (well, at least the stock box) and it seems to seal fine
Old Apr 24, 2002 | 04:29 PM
jetydosa's Avatar
25 Year Member
Default Re: Icebox and K&N filter question (Toda Party)
What I want to do is use the K&N filter in the Icebox with the stock elbow. Does anyone know if this is possible?
[Modified by Jetydosa, 11:45 PM 4/24/2002]
Old Apr 27, 2002 | 03:04 PM
98itr896's Avatar
Ok, just finished installing the Ice Box. It unit looks real cheap, i think, not installed compared to everything you take off. I don't think this is so bad though. Install was very simple. The only "Fitment Issue" i have is with the A/C, i think, line that runs next the air box. The nut on that line rubs the down tube and looks like it would eventually wear a hold in the tube. To cure this, hopefully, i fashioned a plastic protector around the nut so what rubs against the Ice Box down tube is plastic on plastic and should be ok. i'll keep an eye on it.
Anyway, on the air filter for the Ice Box. Well, after measuring and checking and re-measuring it looks like the K&N OEM replacement filter could work in the Ice Box. A local shop ordered a couple for me and should be in next week. I’ll test fit these to check the fitment for sure. One thing I did find out was the stock filter fits the Ice Box. It is a little tight around the rubber seal where the filter seals the air box, but it fits. I am running it this way until the K&N’s come in. Stay tuned…
Old Apr 27, 2002 | 03:07 PM
Driver's Avatar
Default Re: Icebox and K&N filter question (98itr896)
I'm getting that filter ! NICE...
Old Apr 27, 2002 | 09:01 PM
jetydosa's Avatar
25 Year Member
Default Re: Icebox and K&N filter question (01-1214)
Cool, let us know how it goes with the K&N.
Old Apr 27, 2002 | 11:47 PM
underrated99si's Avatar
Default Re: Icebox and K&N filter question (Jetydosa)
nice set up
Old May 9, 2002 | 08:48 AM
98TypeR896's Avatar
ok, finally the E2427 came off of back-order and the shop got their shippment yesterday. here is the definitave answer on the K&N filter in Comptech's Ice Box.
The E-2427 fit like a glove in the Ice Box on the stock intake tube.
Now, i wish we could add this to a sticky faq section like the i-club forums have, along with a host of other valuable information this board has accumulated over the years.
LillDragun
Feb 10, 2003 06:19 AM
ntt
Jan 4, 2003 10:17 PM
Chayse
Dec 15, 2001 08:12 AM
JSIR
Aug 6, 2001 11:21 AM
