hondata intake manifld gasket vs. passwordjdm?
Old May 7, 2006 | 06:18 PM
recognize408's Avatar
Default hondata intake manifld gasket vs. passwordjdm?
Did a search and didnt come up with anything, does anybody know or heard anything about the quality of the password jdm intake gaskets compared to the hondata ones?
Old May 7, 2006 | 06:27 PM
SkankyEJ7's Avatar
Default Re: hondata intake manifld gasket vs. passwordjdm? (recognize408)
whatever you get just be sure to put it up against your intake manifold ports and make sure the gasket DOES NOT interupt the air flow. youll thank yourself later
Old May 8, 2006 | 08:24 AM
GetawayInMoscow's Avatar
Default Re: hondata intake manifld gasket vs. passwordjdm? (neo_)
I'm using ANR's. It's cheaper than both of the ones you mentioned and it matched up perfectly to my AEBS manifold.
Old May 8, 2006 | 08:26 AM
RaceCarRyne's Avatar
Default Re: hondata intake manifld gasket vs. passwordjdm? (GetawayInMoscow)
they all do the same thing.. just like 98ekhx said.. make sure it does not restrict air flow..
Old May 8, 2006 | 04:33 PM
thnx for the help.
Old May 30, 2006 | 10:51 AM
Don Napier's Avatar
Import Alliance
Default Re: (recognize408)
The material that it is made out of is a difference too.
Old Jun 23, 2006 | 08:22 PM
gakkuken's Avatar
Default Re: (NextGear Don)
this might be dumb.... but i heard some ppl complain about the oem stud being a bit short after they install aebs/skunk2/blox aftermarket manifold w/ those hondata gasket.
i'm planning on doing this setup as well... where do i get longer stud from?
Old Jun 23, 2006 | 10:33 PM
DOMKID's Avatar
Default Re: (gakkuken)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gakkuken &raquo;</TD></TR><TR><TD CLASS="quote">this might be dumb.... but i heard some ppl complain about the oem stud being a bit short after they install aebs/skunk2/blox aftermarket manifold w/ those hondata gasket.
i'm planning on doing this setup as well... where do i get longer stud from?</TD></TR></TABLE>
kingmotorsports.com has a kit, very nice.
Modified by Felix. at 9:38 AM 6/25/2006
Old Jun 24, 2006 | 03:21 AM
gakkuken's Avatar
Default Re: (Felix.)
that's just perfect, thx!
Old Jun 24, 2006 | 08:22 AM
Spo0NFed E M 1's Avatar
im using Hondata's w/ my BLOX manifold, never had a problem w/ stud length
Old Jun 25, 2006 | 08:34 AM
Tuesday Club's Avatar
Default Re: (All MTR xsI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by All MTR xsI &raquo;</TD></TR><TR><TD CLASS="quote">im using Hondata's w/ my BLOX manifold, never had a problem w/ stud length</TD></TR></TABLE>
Same setup here.....W/ PROBLEMS
Old Jun 25, 2006 | 11:03 AM
dinko's Avatar
Default Re: (Tuesday Club)
just go to your hardware store and get like 1/4" longer studs + locktite and youre good to go. i had to do it with my gsr head + s2 + hondata gasket
Apr 7, 2009 08:04 AM
grenthang
26
Dec 2, 2004 07:12 PM
Reelizmpro
Oct 5, 2004 01:11 PM
B18C2_sedan
15
Mar 7, 2004 11:17 PM
bottledcrx
May 11, 2003 05:15 PM
