HELP! Tires are getting EATEN ALIVE!
Old May 7, 2006 | 05:54 PM
b16a2EBP's Avatar
Default HELP! Tires are getting EATEN ALIVE!
Help! I lowered my car with some coilovers, and just put on a camber kit. Now both front tires are getting chewed up badly! The passenger side is having negative camber wear, while the driver side is having positive! What's wrong here??? Will a specialist from an allignment place diagnose the problem? Thanks!
Old May 7, 2006 | 06:00 PM
.brian.'s Avatar
Default Re: HELP! Tires are getting EATEN ALIVE! (b16a2EBP)
did you get an alignment after you lowered the car? it is probably your toe.
Old May 7, 2006 | 06:14 PM
b16a2EBP's Avatar
No, but i think it's the toe too! AHHHH!
Old May 7, 2006 | 06:16 PM
97tegGS's Avatar
Yea, an alignment specialist should know what to do.
If it's an older shop I would explain how some of the aftermarket adjustment might work if they've never seen them before but I would have it aligned Asap.
Old May 7, 2006 | 06:19 PM
.brian.'s Avatar
Default Re: (b16a2EBP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a2EBP &raquo;</TD></TR><TR><TD CLASS="quote">No, but i think it's the toe too! AHHHH!</TD></TR></TABLE>you have to get an alignment after messing with your suspension. how long ago did you lower the car?
camber does wear tires, but not nearly as bad as toe will. with a lowered car, i suggest getting an alignment every 6 months, or at the very minimum once a year. otherwise, expect to go through tires like there is no tomorrow.
Old May 8, 2006 | 12:47 AM
VTECcnIT's Avatar
Default Re: (.brian.)
get an alignment and whipe up those tears
Paulybrownktown
21
Jun 29, 2009 03:35 PM
DJNauTicz
Oct 9, 2007 03:27 PM
Nicks95GSR
Dec 22, 2006 07:56 AM
VtecFreePrelude
Sep 29, 2006 08:21 AM
SpeedMachine
Suspension & Brakes
12
Nov 19, 2005 01:17 PM
