20x8x14 inch M&H slicks fit on honda oem 14" steel rims?
Old May 7, 2006 | 04:57 PM
teefunk01's Avatar
Default 20x8x14 inch M&H slicks fit on honda oem 14" steel rims?
just as title states will it work? I think honda oem is 5.5 and the tires are 8...
Old May 7, 2006 | 04:59 PM
.RTErnie's Avatar
Default Re: 20x8x14 inch M&H slicks fit on honda oem 14" steel rims? (teefunk01)
no... the 6" wide slicks will work tho. the 8" slicks you need a wider rim.
Old May 7, 2006 | 05:04 PM
teefunk01's Avatar
Default Re: 20x8x14 inch M&H slicks fit on honda oem 14" steel rims? (~RTErnie~)
what would happen if mounted? would they fall off the rim?
Old May 7, 2006 | 05:32 PM
.RTErnie's Avatar
they'd come off the bead very easily...that is IF they could seat the bead...basically you'd be going 100 mph at the top of the track to have your tire come off the rim.
Old May 7, 2006 | 06:50 PM
CoreyR's Avatar
i have 20x8x14 slicks on stock honda steelies and they've made passes @120+ they will be fine.
Old May 7, 2006 | 07:04 PM
.RTErnie's Avatar
Default Re: 20x8x14 inch M&H slicks fit on honda oem 14" steel rims? (CoreyR)
Acceptable practice for rim width is tread width plus or minus 1 inch. All dimensions @ 10 psi cold on measuring rim
tread width via MT's side = 8"
Honda 14" rim 5.5 at best...but even if we gave you 6" you're still 2" shy and 1" shy of acceptable.
Its your safety and your car to chance...I've seen people do dumber things and get away with it...doesn't mean that you should do it.
Old May 7, 2006 | 07:09 PM
CoreyR's Avatar
your goingin a straight line so theres really no way for the bead to come off.
Old May 7, 2006 | 07:20 PM
.RTErnie's Avatar
HAHAHA! If you've ever gone 120+ in a striaght line you know your car floats on the slicks...and there is a LATERAL load on the slicks whether you want to admit it or not.
Old May 7, 2006 | 07:34 PM
teefunk01's Avatar
I did get the bead to seat properly... my mph trap is usaully 97-99 mph...on street tires and drag radials...didnt think about the width of rim/tires until I read this recently...hmmm
Old May 7, 2006 | 07:38 PM
CoreyR's Avatar
yeah but im really just not worried about it
plus im probably one of 3 million others that have mounted wider tires on thinner rims and ive yet to hear of a problem. what your saying about it comming off the bead is just a theory really because 99% of the time it wont happen
Old May 7, 2006 | 08:05 PM
Han Solo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoreyR &raquo;</TD></TR><TR><TD CLASS="quote">yeah but im really just not worried about it
plus im probably one of 3 million others that have mounted wider tires on thinner rims and ive yet to hear of a problem. what your saying about it comming off the bead is just a theory really because 99% of the time it wont happen</TD></TR></TABLE> id rather be safe than sorry and run the 6in slicks
Old May 7, 2006 | 08:13 PM
.RTErnie's Avatar
Default Re: 20x8x14 inch M&H slicks fit on honda oem 14" steel rims? (KINGSOL18)
People also run 20psi on a RRFPR...doesn't mean its smart.
Old May 7, 2006 | 09:59 PM
Calvinator's Avatar
i also run 20x8x14 on honda steelies with no problems.
Old May 7, 2006 | 10:20 PM
xtrafastcivic's Avatar
Default Re: 20x8x14 inch M&H slicks fit on honda oem 14" steel rims? (xtremeazian)
why would you want to run this slick size? and the right person to answer this is John@m&h..
Old May 7, 2006 | 11:04 PM
Calvinator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xtremeazian &raquo;</TD></TR><TR><TD CLASS="quote">i also run 20x8x14 on honda steelies with no problems.</TD></TR></TABLE>
i personally didnt choose. I got a good deal on these slicks, which were already mounted on the steelies. So I just run them.
cjordan
Feb 17, 2010 07:29 PM
CoreyR
Northeast (Sales)
Nov 22, 2007 07:14 PM
C8V6C
Jul 18, 2005 06:41 AM
B18C1_T
Feb 21, 2003 09:14 AM
arren123
16
Oct 8, 2001 03:00 PM
