Intake Dia. and length
Old May 7, 2006 | 04:04 PM
esteen2's Avatar
Default Intake Dia. and length
Has any one ever tested different diameter and length, for best power, torque, and throttle response. I have a d16 and heard I should use 2.5 dia.
Thanks
Old May 7, 2006 | 04:09 PM
lohatch's Avatar
Default Re: Intake Dia. and length (S2R Honda)
differs for every engine.
Old May 8, 2006 | 12:02 PM
esteen2's Avatar
Default Re: Intake Dia. and length (lohatch)
Ok my motor is a d16a6 (non-vtech) 11.0:1 compression, Skunk2 intake manifold, ported head with 1mm o.s. valves. Web 376 grind cam. What diameter tubing should I use, and should it be short or long.
Thanks
Old May 8, 2006 | 12:33 PM
lohatch's Avatar
go to a dyno and try some different things. try to find a scrap yard that has some tubing. maybe a muffler shop would have some chunks you can grab out of the scrap pile. then go to the dyno and see. add on each time. you can even use duct tape for this part. make sure you have a filter(preferably one with a radiused inlet) or velocity stack on the end of your intake each time so you get consistant results. then when you find which seems to work the best measure it and you can make on that length within the constraints of you engine bay.
a couple years ago i ran an AEM ITR cold air intake on a D16a6 with 10.8:1, ported head, camshaft, y8 manifold, 60mm tb and header and it seems to run well. i never dynoed it against any other intakes however.
raverx3m
Jun 18, 2012 08:01 AM
txenxo
Dec 27, 2008 06:41 PM
logg_frogg
20
Sep 17, 2008 12:01 PM
koczeka
13
Jul 6, 2007 10:01 AM
IheartHondas
Honda S2000
23
Apr 14, 2005 11:08 AM
