Just swapped a d16z6 into my cx hatch ?ecu question?
Old May 7, 2006 | 03:58 PM
pip9's Avatar
Default Just swapped a d16z6 into my cx hatch ?ecu question?
Is is ok to run the stock cx computer until i install my turbo and tune with my hondata chipped ecu?
I just got my engine running today in my cx hatch. z6 head/ y7 block. I dont have a stock p28 at the moment. Car seems to idle and drive pretty smooth with the cx ecu in it.
Old May 7, 2006 | 04:06 PM
SVOboy's Avatar
If you insist on this, I would not drive it hard. The cx ecu is made for 190cc injectors so it ought to get fucked up enough because of the z6 240s to make it run rich enough so that it won't get fux0red, but who knows for sure until you try.
Old May 7, 2006 | 04:30 PM
pip9's Avatar
Default Re: (SVOboy)
i think it is running pretty rich with the cx ecu with the z6 engine. the plugs are pretty black. i dont want to run this cx ecu but it seems like a waste of money to go out and buy another p28 when im going to put my hondata ecu in, in acouple weeks when i put my turbo on.
well i'll see if i can borrow a p28 from someone til then. thanks
edit: what if i put my cx injectors in with the cx computer? I'm not going to be getting on the car much since it still only has less than 10 miles on it.
Old May 7, 2006 | 04:35 PM
SVOboy's Avatar
Then it'll run pretty lean, not terribly though,
Old May 7, 2006 | 04:51 PM
t0p_sh0tta's Avatar
I thought that all d-series injectors were the same?
Old May 7, 2006 | 04:56 PM
SVOboy's Avatar
I believe that vx and cx are both 190cc, I have seen it on h-t a few times and someone confirmed they were different for me once but didn't know the size. And that would account for the richness he is experiencing.
Old May 7, 2006 | 05:13 PM
pip9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy &raquo;</TD></TR><TR><TD CLASS="quote">Then it'll run pretty lean, not terribly though, </TD></TR></TABLE>
why would it with cx injectors and the cx ecu?
Old May 7, 2006 | 05:17 PM
SVOboy's Avatar
Because the z6 is hungrier than the cx was.
Old May 7, 2006 | 06:59 PM
ReDHaTcHyGuy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy &raquo;</TD></TR><TR><TD CLASS="quote">I believe that vx and cx are both 190cc, I have seen it on h-t a few times and someone confirmed they were different for me once but didn't know the size. And that would account for the richness he is experiencing.</TD></TR></TABLE>
92-95 they are all the same the 96-00 dx /cx had 190's not 92-95 cx's
Old May 7, 2006 | 07:04 PM
SVOboy's Avatar
Are you sure, because I have seen this in reference to vx injectors also.
noob1971
Dec 26, 2014 10:27 PM
BrokeasHell
Nov 7, 2006 03:36 PM
SLowCrx
Mar 16, 2004 04:35 PM
92HB_HB
Jan 24, 2002 07:45 PM
