No ABS on the Prelude S series?
Old May 7, 2006 | 03:22 PM
NoVALude's Avatar
Default No ABS on the Prelude S series?
I bought (2) front knuckles from a fellow member, but my Si has ABS sensors, and the knuckles did not have any place to attach the sensors....
Does that mean that I have to ditch my ABS, or is there a way to still somehow attach them to be used?
Old May 7, 2006 | 03:25 PM
tytyguy's Avatar
what year is it?
Old May 7, 2006 | 04:02 PM
NoVALude's Avatar
Default Re: (tytyguy)
See sig...
Old May 7, 2006 | 04:43 PM
soundbomber's Avatar
Default Re: (NoVALude)
the ones i sold you didn't have abs sensor provisionS? i'm pretty certain they did?
Old May 7, 2006 | 04:57 PM
NoVALude's Avatar
Default Re: (soundbomber)
I took the old knuckle off and put the new one on and had to double check....was not able to find the 2 extra holes to install the ABS sensor....either side.
Not the end of the world, just need to know what to do about the sensors and the effect on brake performance
Old May 7, 2006 | 04:59 PM
oh crap, i'm sorry man...i didn't know, the guy listed the auction as an Si
Old May 7, 2006 | 07:27 PM
NoVALude's Avatar
hey, no complaints about what I got....
just not sure what to do with the sensors....
Old May 7, 2006 | 08:04 PM
FadeToBlack's Avatar
Yeah, not sure about the sensors, but the Prelude S does not have ABS.
Old May 8, 2006 | 05:00 AM
NoVALude's Avatar
Default Re: (FadeToBlack)
Morning bump.....do the sensors monitor the vibration of the brakes? If I can zip tie them out of the way I will, but if they are still wired, but just not bolted down, that shouldnt affect any codes should it?
Old May 8, 2006 | 05:19 AM
mgags7's Avatar
no, those sensors read notches off the axle as it turns, for abs to function, they need to be in the oe location....
Old May 8, 2006 | 07:52 AM
NoVALude's Avatar
Default Re: (mgags7)
so either I drill and tap holes on the knuckle for the sensors, or zip tie the wires to the side and unplug the sensors at the harness?
Old May 8, 2006 | 08:10 AM
mgags7's Avatar
well if youre gonna take the sensors out you might as well ditch the whole system....
drilling and tapping holes for these and getting everything to line up right is gonna be pretty difficult
Old May 8, 2006 | 08:27 AM
NoVALude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">drilling and tapping holes for these and getting everything to line up right is gonna be pretty difficult</TD></TR></TABLE>
I definitely do not want to get into that chaos....! there are (4) sensors right...one for each wheel. just take out the (2) front ones, will the back still work?
where is the best place to disconnect as to not throw any ABS codes or anything?
Old May 8, 2006 | 12:26 PM
mgags7's Avatar
its gonna throw codes if you disconnect
Old May 8, 2006 | 12:42 PM
NoVALude's Avatar
so then I need to tie them out of the way in the wheelwell somewhere?
Old May 10, 2006 | 08:03 AM
mgags7's Avatar
if theyre not in their 100% stock location you're gonna throw a light....
Old May 10, 2006 | 11:02 AM
NoVALude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">if theyre not in their 100% stock location you're gonna throw a light....</TD></TR></TABLE>
sucks...and I take it is a PITA to disconnect the wires completely from the system.....
any suggestions?
Old May 10, 2006 | 11:07 AM
Hawkze_2.3's Avatar
You could take the ABS out completely....or just take the ABS light bulb out.
Sounds like it's not going to function anyway...
Old May 10, 2006 | 12:22 PM
NoVALude's Avatar
Default Re: (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">You could take the ABS out completely....or just take the ABS light bulb out.
Sounds like it's not going to function anyway...</TD></TR></TABLE>
of the two, which is less of a PITA? can I just unplug the wire from the ECU (for the ABS)?
Old May 10, 2006 | 12:39 PM
u could just unplug the fuse and tuck away the harness, and again, i'm really really sorry man
Old May 10, 2006 | 01:06 PM
NoVALude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundbomber &raquo;</TD></TR><TR><TD CLASS="quote">u could just unplug the fuse and tuck away the harness, and again, i'm really really sorry man </TD></TR></TABLE>
if this is all I have to do then really man...no problem. Just glad to have new knuckles and rotors/calipers/pads on the front.
josh-roy
Jul 30, 2010 02:32 AM
george34
Jun 27, 2005 11:01 AM
Scither69
Jun 12, 2004 02:17 PM
Fraggle
Nov 2, 2003 11:03 AM
Bigphlip
May 12, 2003 11:54 AM
