94-01 GSr Knock Sensor Replacement - Advice Needed
Old May 7, 2006 | 12:00 PM
Dogginator's Avatar
Daisy... Daisy...
Default 94-01 GSr Knock Sensor Replacement - Advice Needed
The casing on the knock sensor in my 97 GSR was cracked. I epoxied this a while ago, but now have a new sensor. It is time to properly replace it.
The knock sensor is basically sandwiched between the intake manifold and the water pipe on the back of the engine. It looks like the hex is a 27mm. Does anyone have any advice for getting a socket on the knock sensor to remove it? I would like to remove as little as possible, especially the intake manifold. I was planning to use an extension with a swivel. Thanks!
Edit: The thread size was 27mm. I hate socket sets that skip sizes.
Modified by Dogginator at 5:10 PM 5/7/2006
Old May 7, 2006 | 12:31 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 94-01 GSr Knock Sensor Replacement - Advice Needed (Dogginator)
Here is a link.
https://honda-tech.com/zerothread?id=1506233
Old May 7, 2006 | 01:00 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: 94-01 GSr Knock Sensor Replacement - Advice Needed (tech8)
Thanks for the link. I searched and just didn't notice that thread. I have the oil cooler with which to contend.
Old Jul 10, 2006 | 08:45 AM
WHAT TEH's Avatar
idk tha metric size, but i'm sure you can google it. as for it's standard size, it's 1-1/16. good luck.
_taF
apoptosis
Feb 17, 2008 08:13 PM
alexb18c1
May 7, 2006 12:52 PM
SiR831
Dec 25, 2003 11:01 PM
DubbleD
May 29, 2003 12:12 PM
rjardy
May 23, 2003 01:27 AM
