fresh motor is leaking oil.
Old May 7, 2006 | 11:29 AM
iheartmyej8's Avatar
Default fresh motor is leaking oil.
i have brand new ls/vtec motor. we just got done with putting everything in the car. i have a b16a1 head/ b18a1 block. we started the car then turned it off b/c oil was leaking(pretty good amount). the oil is coming out at the back of the head from around the headgasket, on the side next to the cam gears. i have ge headgasket and arp head studs. does anyone have any suggestions on what could be the prob. or if anyone has had this prob b4?
Old May 7, 2006 | 11:33 AM
Yambor's Avatar
wrong hg? lol
um, didnt torque the head down right, upside down hg.
Old May 7, 2006 | 11:37 AM
Default Re: (Yambor)
i called ge and they said the have used that headgasket for 5 years no problems, should i be using a b16 or ls headgasket? what is the trq specs we called arp and they said 70lbs so thats what we did. and the hg was in the up position when we put it one.
Old May 7, 2006 | 12:21 PM
Micha's Avatar
FAILWGN
Default Re: (iheartmyeg)
Sounds like you maybe forgot to put in a cam seal or something? The 2 little o-rings on the cam gear side.
Old May 7, 2006 | 12:34 PM
Default Re: (Blu99teg)
would that make it leak on the back of the head?
Old May 7, 2006 | 12:52 PM
DC2 Mang's Avatar
was the deck and the surface of the head totally free of any deep sctratches? deep ones could provide a path for the oil to escape
it should not be a problem with the gasket unless you put it on wrong because golden eagle takes all the necessary steps for you by eliminating o-rings on the gasket that would create and improper seal
Old May 7, 2006 | 04:04 PM
Default Re: (JDMdc2lsVtec)
i think the head was clear on deck and scratchs. should i have used and ls or b16 head gasket? b/c golden eagle sent me the b16. i didnt know if that had anything to do w/ it.
Old May 7, 2006 | 06:04 PM
DC2 Mang's Avatar
you should be using an LS head gasket
Old May 7, 2006 | 06:23 PM
Dartanian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMdc2lsVtec &raquo;</TD></TR><TR><TD CLASS="quote">you should be using an LS head gasket</TD></TR></TABLE>
No you shouldn't. An ls headgasket doesn't have same oil holes as a vtec headgasket does.
If it is leaking a ton of oil when started between the block and head, you put the headgasket on upside down. It is a common mistake if you aren't paying attention because it will bolt down just perfectly regardless of whether it is right side up or not. You will only find out that you put it on wrong when you try and start the car and it starts gushing oil.
Old May 7, 2006 | 06:25 PM
DC2 Mang's Avatar
Default Re: (Das Schmoo)
ive done more than 5 LSvtecs and used LS head gaskets everytime and never had a leak
Old May 8, 2006 | 03:30 AM
well i thought that you had to use a ls head gasket but i called ge and they use factory b16 and they just bore out the holes for the dowl pins
Old May 8, 2006 | 06:56 AM
DC2 Mang's Avatar
Default Re: fresh motor is leaking oil. (iheartmyeg)
if your headgasket was upside down you would gush oil, it just happened to me in my haste to put my gsr motor back together
Old May 8, 2006 | 01:09 PM
I would say its the head gasket too. Use a LS Head gasket next time. None of my homies have ever used a b16 head gasket on a LS/Vtec swap. Even on b20/Vtec swaps we used the b20 head gasket. Allso check the cam seals because sometimes you might think its coming from the head gasket but it is actually coming from the cam seals and building up all over where the head meets the block. Good Luck though!!!!
Old May 8, 2006 | 01:40 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iheartmyeg &raquo;</TD></TR><TR><TD CLASS="quote">i have brand new ls/vtec motor. we just got done with putting everything in the car. i have a b16a1 head/ b18a1 block. we started the car then turned it off b/c oil was leaking(pretty good amount). the oil is coming out at the back of the head from around the headgasket, on the side next to the cam gears. i have ge headgasket and arp head studs. does anyone have any suggestions on what could be the prob. or if anyone has had this prob b4?</TD></TR></TABLE>
make sure the oil isn't running down the head. If the cam seals are not put it "straight" they will back out fairly easily and leak allot of oil quickly.
Old May 8, 2006 | 05:10 PM
Default Re: fresh motor is leaking oil. (skunked)
well im putting a cometic ls/vtec headgasket on there in a gouple of days. and i will look at the cam seals while we are in there. i want to go ahead and put a new headgasket on there just to make me feel safe.
Old May 8, 2006 | 05:23 PM
CleanLikeJdm's Avatar
Hype-R Stalker
That's what I always thought also.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Das Schmoo &raquo;</TD></TR><TR><TD CLASS="quote">No you shouldn't. An ls headgasket doesn't have same oil holes as a vtec headgasket does.</TD></TR></TABLE>
Is there more then just the one you plug, and reroute the oil?
Old May 8, 2006 | 05:54 PM
Default Re: (FlatBlackTeg)
well i guess it has some holes were they dont need to be.
Old May 8, 2006 | 08:03 PM
Noemotion_91DA's Avatar
You might to get the head resurfed
Old May 9, 2006 | 10:11 AM
Default Re: (Noemotion_91DA)
the head work was done by autolabz in alabama. and when we went to but everything together both the head and block was clear and even. i had the block decked here at a place in tenn. so today i am goin to order a cometic gasket. they base their gasket off an ls headgasket, and b/c of name and rep. i will be more happy to get one from them.
eglover20
Jul 22, 2010 07:00 AM
dartonh22
Aug 8, 2008 11:44 AM
iheartmyej8
15
May 9, 2006 01:36 PM
zx2gotboost
52
Jan 8, 2006 09:03 PM
CiSmoEk4
10
Dec 25, 2005 05:56 PM
