Frame bent?
so heres the deal. i got into an accident last winter and have finished "fixing" my ride. (95 del sol) i changed the LCA, UCA, steering knuckle and shock. so today i took it out for a little drive. unfortunetly it does not drive straight. (curves to the left. im really scared the frame is bent and i have no idea what to change next. the steering column maybe? anyway other than what i already changed all i need is airbags and a door. so idk im really lost on what to do. ive worked my *** off fixing this car and if the frame is bent i dont know what ill do. any advice would be appreciated. i was thinking about changing the thingie that steers the car(connects to the knuckle) but i dont know what its called. thanks ~victor
no i didnt, cuz i really cant drive it anywhere without airbags and i dont wanna spend more money till i tell if the frame is bent. i crawled under the car and it seems that the steering box is broken. so im gonna change that too... anyway an alignment wouldnt help that much cuz its swaying to the left pretty bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KINGSOL18 »</TD></TR><TR><TD CLASS="quote"> anyway an alignment wouldnt help that much cuz its swaying to the left pretty bad.</TD></TR></TABLE>
yes it will you ******* idiot. get an alignment done they will tell you whats wrong if something is wrong. what a ******* dumb *** you are
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20eg66 »</TD></TR><TR><TD CLASS="quote">
yes it will you ******* idiot. get an alignment done they will tell you whats wrong if something is wrong. what a ******* dumb *** you are</TD></TR></TABLE> allriight buddy chill the expletive out. if you would read what i said you would see that i cant drive it anywhere cuz i dont have any ******* airbags or turn signals. anyway i traced the problem to the steering rack, so i just ordered a new one and ill go from there
1) They're right. With what you did, you can't even expect it to steer right without an alignment.
2) The problem with the horn/blinkers and airbag's in the steering COLUMN wiring not in the rack.
3) You may have bent "crossmember to body" bolts which shifted the crossmember. I'd pull them out one at a time and check them. If the crossmember has shifted (which an alignment would tell you) you can't set the suspension properly.
You're basically wasting money doing anything other than an alignment.
As for not driving it, it's only a problem if you get caught.
cops are everywhere where i live. so there is no way for me to get to an alignment shop without getting caught. anyway, thats why i didnt get a professional alignment. one of my buddies however did do a ghetto alignment so i know the camber is ok(not sure about toe) as i said my steering gearbox is broken cuz the shock of the accident broke that little pittly rubber screw. there is now a big gap in the box and i can see the rack. ill keep you posted
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin »</TD></TR><TR><TD CLASS="quote">hahaha
wow
guess what
your gonna need an alingment after the new rack.
and guess what else. an alingment would have fixed this problem in the first place. </TD></TR></TABLE>
own3d
On another note, if you wanna know if ur frame is bent, measure 2 spots (e.g. axle to axle) and see if the measurements are off. If you have AAA have ur car towed to get the aligment, its free with a membership.
wow
guess what
own3d
i dont have AAA and why would an alignment have fixed my problem? ill take a pic of the steering box tomorrow so youll see the extent of the damage. i understand i should have gotten an alignment and i would have if i wouldnt have figured out the steering box was bad. i made this post before i thought of getting an alignment and i will after my new steering box is installed
either way an alignment wont fix a bent frame. you need to have your car put on a frame machine and measured and pulled if need be, also have them check all the suspension and engine cradle to make sure nothing is shifted. do not mistake frame measurment for breaking out the stanley 25 ft tape measure, it is a very precise thing that needs to be done by a professional that has training and the right equipment. once this is done then you should proceed to have a 4 wheel alaignment. and what the hell does an airbag have to do with driving your car? unbolt them or razor knife them bitches off and get your **** fixed. if your car is as bad as you described it shouldnt be hard telling po po " yessir I know my car is f*cked, but thank you for pulling me over to remind me again. now if you done i'd like to continue on my trip to the body and/or alignment shop to get my f*cked car fixed." anyway good luck man.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KINGSOL18 »</TD></TR><TR><TD CLASS="quote">one of my buddies however did do a ghetto alignment</TD></TR></TABLE>
just the word "ghetto" should ring a bell that u should find a way to get it to a professional so they can do an actual alignment, taking the word 'ghetto' out
Nobody here can help you unless you have gotten it aligned. Sounds like you need to get the car towed to a body shop and put on a frame machine then an alignment. If you go to a good place for your alignment they will most likely be able to tell you if there is something else wrong.
Fiero
11
Nov 18, 2007 08:06 AM
