ecu wiring gremlin help
Old May 7, 2006 | 06:54 AM
handlebarsfsr's Avatar
Default ecu wiring gremlin help
i have an obd2 b series swap into a 5th gen that refuses to start. the car only sporadically primes the fuel pump and kicks the relay, but it does do it sometimes. if i dont connect 'd' to my ecu, it will kick and prime every time. if i plug in d, i will turn on neither the fuel pump or the main relay, and it prevents anything to go to the dizzy. without 'd' i get both f uel and spark, but it wont start. the car is also throwing a cel code 4, for crank position sensor, but i just replaced the dizzy with a brand new one and it didnt fix the problem. i assume its a ground or bad connection somewhere, but i rechecked all my grounds and everything seems to be in order. yesterday, all i had to do was shake the clips on the passenger side shock tower to make the relay kick over with all 3 plugs in the ecu, but today that doesnt work.
Old May 7, 2006 | 07:55 AM
Relic1's Avatar
you've all eady located the problem. Shaking the shock tower plugs are a dead giveaway that you have a falult connection in the plugs or a wire that's broken.
Try cleaning up all the connections in te connectors at the shock tower. If that's doesn't help try wiggling individual wires before and after the plugs.
It will take time but you will find the problem.
Old May 7, 2006 | 11:01 AM
does anyone know which wire on plug d would cause it to short out the rest of the ecu? because when i unplug d, the fuel pump primes and the relay kicks, but when i plug d in, it cancels out both of those. the only wire that even looks like it could do that is the sensor ground on d22
Old May 8, 2006 | 06:43 PM
bump for any ideas>?
Nick7
May 14, 2011 08:57 AM
mlb4046
Jan 23, 2011 03:53 PM
a1320honda
Nov 26, 2009 07:46 PM
Lucky-13
Mar 23, 2007 09:33 PM
