How to tell injector clips apart?
My friend got a box of misc d series parts.
We have 2 sets of injectors and 2 sets of injector clips
One set of clips are white the other are grey
The question is How do we tell which are obd0 and which are obd1
Thanks.
Thanks.
the white clips are most likely preobd and the gray clips are most likely obd1.
you can get a ohmmeter and check the coils on the injectors.
preobd(peak &hold) should ohm out at 1.5-2.5 ohms.
obd1 (saturated) should ohm out at 10-12 ohms.
the obd2 clips i've seen are black and don't require a screwdriver to seperate the clip from the injector.
BoRiCuA
Jul 6, 2013 08:57 AM
