Suspension & Brakes Theory, alignment, spring rates....
poly bushings for EG front upper control arms?
Old May 7, 2006 | 03:37 AM
an2ny888's Avatar
Default poly bushings for EG front upper control arms?
am looking for feedback on using poly bushings for the front upper control arms on an EG. do these make a difference you can feel? or is squeaking the only thing they're good for?
Modified by an2ny888 at 2:57 AM 5/8/2006
Old May 7, 2006 | 08:46 AM
PIC Performance's Avatar
Default Re: poly bushings for EG front upper control arms? (an2ny888)
What is the car being used for, and do you understand the function of using PU for bushings?
Old May 7, 2006 | 05:56 PM
an2ny888's Avatar
Default Re: poly bushings for EG front upper control arms? (PIC Performance)
daily driven with occasional autox. i am familiar with the function of poly in bushings, as well as its disadvantages. what i'm asking is will these upper arm bushings( by themselves) make a difference that i can feel? or is their effect on handling very subtle?
Old May 8, 2006 | 12:42 PM
DavidR's Avatar
https://honda-tech.com/zerothread?id=1563815
Old May 8, 2006 | 05:12 PM
an2ny888's Avatar
Default Re: poly bushings for EG front upper control arms? (DavidR)
yeah i read that before, it's one of the reasons why i haven't installed this poly upper arm yet
Old May 8, 2006 | 05:31 PM
In that case I don't think you should switch to polyurethane bushings. You will feel the difference in a harsher ride, and a lighter wallet. Is that worth it in a car that is daily driven and may or may not see auto-x duty in a year?
mattbatson
Suspension & Brakes
Mar 7, 2010 02:23 PM
egvtec
Nov 3, 2007 06:31 PM
Homotor
Jan 28, 2007 07:06 PM
Jonathan_ED3
Jul 11, 2006 07:25 PM
bad93ex
Jan 6, 2003 11:03 AM
