suspension noise
Old May 6, 2006 | 09:11 PM
pos_cd5's Avatar
Default suspension noise
the front passenger side suspension squeaks really bad...over slight bumps you can hear slight squeaking but it is really bad when coming to a stop during braking. the squeaking started a few days ago, i havent done anything to the suspension so im pretty clueless to where to start looking. any ideas guys? its a 95 LX 4-cylinder btw
Old May 6, 2006 | 09:39 PM
loup05's Avatar
Default Re: suspension noise (pos_cd5)
check yout bushings most of the time that noise could be caused by old dried up buchings
Old May 7, 2006 | 12:06 AM
accord-pro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pos_cd5 &raquo;</TD></TR><TR><TD CLASS="quote">the front passenger side suspension squeaks really bad...over slight bumps you can hear slight squeaking but it is really bad when coming to a stop during braking. the squeaking started a few days ago, i havent done anything to the suspension so im pretty clueless to where to start looking. any ideas guys? its a 95 LX 4-cylinder btw</TD></TR></TABLE>
you might have 2 different squeaks,,,,,,,
,,1 ,,your brakes when coming to a stop
,,2,, inner stabilizer bar bushings dry and squeaking over bumps.
Old May 7, 2006 | 02:12 PM
pos_cd5's Avatar
Default Re: suspension noise (accord-pro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord-pro &raquo;</TD></TR><TR><TD CLASS="quote">
,,2,, inner stabilizer bar bushings dry and squeaking over bumps. </TD></TR></TABLE>
im 99.999999% sure its not the brakes...i drove it around for awhile to pinpoint the noise and im realy sure its the suspension...i'll take a look at the sway bar bushings though, thanks....
Old May 7, 2006 | 04:41 PM
importfanatic17's Avatar
My car does the same thing and I am going to replace the bushings with polyurethane ones, do they squeak too or are they just a rough ride?
Old May 7, 2006 | 04:51 PM
pos_cd5's Avatar
Default Re: suspension noise (importfanatic17)
they just squeak. the ride feels fine
Old May 7, 2006 | 06:35 PM
Ross 2.0's Avatar
In a Junkyard near you.
I would bet the upper control arm bushings. Since you live in Or. you probably drive in a good amount of salt during the winter. What you can do is jack up your car and look above the tire in the wheel. You will see the upper control arm and it's two bushings that connect to the body. Hose it down good with your water hose, give it plenty of time to dry and then hose it down with penetrating oil.If it goes away and comes back you will need to remove the control arm, clean the bolts and lube the crap out of it.
Old May 7, 2006 | 07:17 PM
pos_cd5's Avatar
Default Re: suspension noise (MooGoCow3)
i sprayed all the bushings down with WD-40 but it didnt help...i guess i'll try to hose and pentrating thing as well as check my sway bar bushings. anymore ideas guys?
Old May 7, 2006 | 10:05 PM
HONCORD's Avatar
Just like MooGoCow3 said, upper control arm bushings.
make a small hole in the rubber boot and spray some penetrating fluid in them. If squeak goes away, you hit the jack pot!. But it'll come back again. At least you would know what to replace.
(Try to bounce your front end up and down, listen for that noise)
Old May 7, 2006 | 10:13 PM
pos_cd5's Avatar
Default Re: suspension noise (HONCORD)
i did bounce it up n down, dats how i knew it was coming from the front passanger side...but i cant pin point exactly where from just listening to it...
Old May 7, 2006 | 10:19 PM
HONCORD's Avatar
Its usually da ball joints in the cars that do that. So try to spray some wd-40 in it, like I said in previous reply. If that dont work, that might be your upper strut mounts thats making that noise.
Let us know.
Old May 8, 2006 | 02:39 PM
pos_cd5's Avatar
alright guys i found the problem...one of the radius rod bushings was missing...i have no idea how it got lost, most of been the alignment i got at les schwab i got a few weeks ago.. but i had a extra bushing laying around and poped it in and now its as quiet as my girlfriend during sex ...thanks for all the replys and trying to help me fix this problem, i appreciate it
Old May 8, 2006 | 03:40 PM
HONCORD's Avatar
glad u found it
kharned08
Honda Civic (2001 - 2005)
Mar 20, 2008 08:37 PM
BrandonClaps
Jun 28, 2003 02:57 PM
EGO
29
Jun 9, 2003 09:10 PM
