JDM B18C1 swap into a 00 SI shell, wiring questions
Old May 6, 2006 | 07:05 PM
devilduck's Avatar
Default JDM B18C1 swap into a 00 SI shell, wiring questions
I have a B18C1 from one of my old civic's and I found a '00 shell and I am having trouble with the wiring. I had the old harness from the other civic on the engine and I got the engine running, but the I could not get the gauges to work right. So I got a SI wiring harness and ECU and swapped them in. After I did the harness swap I can not get the car to crank, and also know for some reason the radiator fan comes on when ever the key is in the on position.
Does anyone have anyone have any ideas?
Thank You
Old May 7, 2006 | 11:10 AM
devilduck's Avatar
Sorry, the car now cranks, but I am not getting any power to my fuel pump and the fan is still going crazy.
Old May 12, 2006 | 12:41 PM
dynamo's Avatar
Default Re: JDM B18C1 swap into a 00 SI shell, wiring questions (devilduck)
Check your grounds and make sure all of your plugs are in the right locations. I had all kinds of weird **** happening until I checked and re-checked all of the plugs on the harness to make it work.
Rickcrx
Mar 9, 2009 05:24 AM
-jacob-
Oct 22, 2008 10:52 AM
notsofastyet77
14
Mar 9, 2007 06:53 AM
thegoods217
Oct 21, 2005 06:22 PM
TOFU.man
Apr 3, 2004 05:52 AM
